Also good to post on here so other members are aware of any issues.
dolphin failed on a jeep CY24.. wouldn't turn the lock.. the angle from the shoulder to first cut is too steep almost 90 degrees.
I went over with a manual machine which didn't touch any of the cuts so they was correct, just took some of the first angle and took a little of the tip, then it worked fine.
condor mini plus is also so problematic as dolphin?
hello...on hu58 never able to read and cut..key jumps out of clamp....
So what's all this noise about Universal Key Blank from Xhorse?
Anyone seen this thing? I bet it looks like a Honda HON66 blank and it doesn't work for regular double side cut keys.
122099627_3492047487521280_7900797010435965795_n.jpg122494844_3492047777521251_2168648578687414430_o.jpg122897432_3503771043015591_2784238521487652084_o.jpg
I didn't know they have it. It seems like the same thing.
The feature that was added to cut 2004-2009 Prius emergency keys appears to have been taken away. (see post #765 this thread) why?
6.0.3. works perfectly. have a try
Condor XC-MINI user here.
HU 64 cloning broke both of my probes.
During detection, probe broke while measuring the blade, I replaced with backup blade and it broke exactly the same place.
Done the same broke probe HU64 twice in same place
sad to hear.. Any fix for this?
Does conductivity test complete OK? If yes, then it is from the firmware and you need to complain to Xhorse in Xhorse App on your phone....
Clean the blade before .
Also decoding hu64 doesn't always work so better decode by eye.
Sent from my MI CC9 Pro Premium Edition using Tapatalk
Oh I did not know probe needs conductivity to operate... Original key was rusty, I cleaned it but as it seems not well enough. I get it now. My mistake.
