Page 116 of 129 FirstFirst ... 1666106111112113114115116117118119120121126 ... LastLast
Results 1,726 to 1,740 of 1932
  1. #1726
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    trying too connect instacode from android with condor mini xc no joy
    use too connect when i first got machine but cannot connect now
    xhorse app works no problem
  2. #1727
    P&D's Avatar
    Hi all I'm trying to make a key profile for the dolphin EU21P 4 track internal M2 clamp side B (customize key data)
    I'm having problems
    the decoding side the key is working perfect (a friend cut the code on his Futura Pro)
    the cutting side is where I'm struggling any pointers would be grateful
    Key shape
    shoulder
    length 2050
    width 760
    thickness 290
    cut depth 90
    Key space
    A 302 - 702 - 1102 - 1502
    B 503 - 903 - 1303 - 1703
    Key flat sides A & B
    I don't know what it means ? what to input
    Cut depth
    A & B = 128 - 178 - 228 278
    Internal axis coordinate
    What is this ?
    I cut the key and I get the these cuts when it decoded (plz see last photo)
    Any pointer would be welcome
    Thank you
  3. #1728
    Jan 2021
    keep your software and firmware are latest
  4. #1729
    whiskeyman's Avatar
    Dec 2010
    Quote Originally Posted by xhorse Jay View Post
    always are
  5. #1730
    Jul 2015
    My Condor Mini KM03 loses the time and date if it is unplugged. Do you know the location and the type of the CMOS battery?
  6. #1731
    Greece
    Quote Originally Posted by gokart View Post
    Is on main board. I replace it on my machine. Need take motherboard out beacuse is on very bad potition. If I remember is 1220 battery
    Στάλθηκε από το S31 μου χρησιμοποιώντας Tapatalk
  7. The Following User Says Thank You to kleidaras For This Useful Post:
    gokart (27th June, 2021)
  8. #1732
    Mar 2016
    Done yesterday a key for master 2012 va2eh2, cut by decode by dolphin xp005
    customers pick up the key from my and says it goes in but not spin the lock
    does the xp005 get problems with them?
    the same time i cut a hu83 and there work without problem
  9. #1733
    P&D's Avatar
    Quote Originally Posted by Madol1 View Post
    when was your cutter last updated ?
    this is fixed with the new update
  10. #1734
    Mar 2016
    Quote Originally Posted by P&D View Post
    The cutter got the newest software and firmware.
    But there is a bug in the software as the master do not use va2 keys but va6
  11. #1735
    Jan 2021
    sir, learn original key and cut key, then contrast the details. when you cut key, should keep it put as require and stable.
  12. #1736
    P&D's Avatar
    Did you decode the key with A-F or Q-H ?
  13. #1737
    Apr 2014
    Quote Originally Posted by fytfh View Post
    Hi my xc mini km03 not start turn on but on screen show only condor xc mini v7.10 and on down side show sn:KM03726138 how to fix this?
    Solved i clear all data and re install last update now work normaly
    How do you clear from this screen?
    Sent from my SM-G930F using Tapatalk
  14. #1738
    Mar 2016
    Someone get problems to cut a va6 by xp-005?
    I use an iphone to manage the machine.
    I got a aygo AKL, read waffers 778344 and the cut it as 77Q651
    the key can not turn the door
  15. #1739
    POLAND
    Is there a problem with the xhorse servers?
    Today I try to cut HU43 from the code and I get "Request failed, please retry later"
    Alternatively, someone will give a cut for H1382
    I reinstalled the app and ....It's worse than it was. I can't connect to KEY TOOL or Dolphin now ..... Synchronize with server, please wait ... and "Request failed, please retry later"
    You don't know the day or time when the Chinese will shut down the server ... now everything works.
  16. #1740
    didi_du_93000's Avatar
    France Paris
    Do l e yesterday by code va6 twingo Mk3.
    All great
    Envoyé de mon SM-G998B en utilisant Tapatalk
