Page 122 of 129 FirstFirst ... 2272112117118119120121122123124125126127 ... LastLast
Results 1,816 to 1,830 of 1934
  1. #1816
    rob h's Avatar
    May 2011
    Yes Hyn10 will fit Atos MX.
  2. The Following User Says Thank You to rob h For This Useful Post:
    auto techniek (25th February, 2023)
  3. #1817
    auto techniek's Avatar
    Mar 2017
    Anyone tried to decode Ford key F021 with condor mini +M3 Clamp
    Was told can only cut.
  4. #1818
    rob h's Avatar
    May 2011
    Best to decode these by eye.
    Some keys are so worn, that it is not easy to do.
    And a worn ign lock, will not always work, with a new cut to code key.
    I do sometimes open up, the ign lock.
    I can see the shim code. And replace the shims, all with new.
    I did see a decoder tool, with 6 tumbler shims, and reading dial.
    SILCA DECODER FORD TIBBE FO21P
    Product Code: SD705322ZB
    Cost about 500euro.
  5. The Following User Says Thank You to rob h For This Useful Post:
    auto techniek (27th February, 2023)
  6. #1819
    Dec 2010
    Nottingham
    decode by eye or pick and decode with tool
  7. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  8. #1820
    rob h's Avatar
    May 2011
    Oem Toyota.jpgVA8 Dolphin.jpgDolphin can not cut the VA8 correct.
    The tip is wrong, it will not be inserted in the locks.
    And the VA6 also needs some attention.
    And the cutting adjustement, of the Hu64, perhaps also other keys does not work.
    Cutting less, it can do, cutting away more, it does not start the cut.
  9. #1821
    rob h's Avatar
    May 2011
    And hu64, in clamp m2 position a.
    It does not clamp, a hu64.
    It will hold a uncut blank.
    Soon as you flip the key, to cut other side,
    You are in trouble.
    It needs to be in clamp b.
    Some hu64 are clamp a some clamp b in the menu,
    And info, on tip to first cut,
    It should display, 380 480 580,
    On the 64-0
    64-1
    64-2
    It is not visible, in the app menu.
  10. #1822
    Mar 2017
    Guys
    Need some help. I m looking for manual key cutter besides condor mini.
    Which one can you advice?
  11. #1823
    peko's Avatar
    hi friends,
    where can i buy good quality blank keys ?
  12. #1824
    rob h's Avatar
    May 2011
    What do you mean, with quality?
    The keydiy blades are fine.
    Most keys, when a track is cut, have a gold color inside.
    A oem key, this key, in en outside stay silver where it is cut.
  13. #1825
    Jul 2019
    Melbourne, Australia
    Bloody hell, I've denigrated the xhorse machines for years, especially after my experiences with the early ones. I often said they were upjumped engraving machines and not suitable for the task of key cutting.
    But I just bought myself a Dolphin II, and I'm fully ready to admit I was wrong on at least this machine. This thing is bloody brilliant especially for the price. Cuts track keys almost as good as my Futura Pro, and the integrations with the KTP and the xhorse app on my phone put the IC/Silca apps to shame. The edge cut keys are absolute garbage though as to be expected from a milling only machine. There are minor quality issues with cutter dwell time etc but dimensionally these keys are pretty damn good.
    I daresay this thing is actually better than my Futura on decoding and cutting HU162T. Plus having S&D cards for say Haval/GW 8-cut track new such as used on new Jolion is bloody brilliant.
    I'm super impressed, I bought this on sale from MK3 and I am really pleased.
  14. The Following 2 Users Say Thank You to Spiritech For This Useful Post:
    godfathertwo (20th September, 2023), Raould (6th July, 2023)
  15. #1826
    Maartinj's Avatar
    Nov 2010
    ..... new Condor MINI Pro II can decode plastic key , they not use anymore metal conductivity, they use a pressure sensor for decoding
  16. The Following User Says Thank You to Maartinj For This Useful Post:
    Weasel3 (31st July, 2023)
  17. #1827
    Feb 2014
    When will they release it ?
  18. #1828
    May 2021
    Looking for some real feedback on the Dolphin II XP-005L thinking of buying one i have seen some problem with motor and errors is it been fixed or better buy older model reliability more important than look for me thank you.
  19. #1829
    Jul 2019
    Quote Originally Posted by godfathertwo View Post
    I have one, it's only cut about 30ish keys so far but no issues whatsoever. It's my secondary machine so it's not used like my Futura Pro every day, just when I have Chinese market cars to cut keys for, or when I'm super busy in one location and have a reason to have two machines cutting at once.
    I've seen the same reports but I haven't had an issue yet myself.
  20. The Following User Says Thank You to Spiritech For This Useful Post:
    godfathertwo (30th July, 2023)
  21. #1830
    May 2021
    Dolphin xp005 or xp005l
    Any users using both of these machines so can make my mind up thank you .
