Page 129 of 129 FirstFirst ... 2979119124125126127128129
Results 1,921 to 1,932 of 1932
  1. #1921
    Jun 2013
    Quote Originally Posted by rob h View Post
    Put a metal blade in the clamp, press start cut:
    Then pause the cutter, just before the cutter reaches the blade.
    Swapp to plastic, and press continue cutting.
    Smart idea!
    I will do it like this in the future.
    Thank you for the tip.
    A time saver.
  2. #1922
    Jan 2017
    Netherlands
    Quote Originally Posted by Weasel3 View Post
    I swapped my M2 clamp to a M5.
    (The M5 is already equipped on the latest machine sold, from supplier).
    Experienced earlier the same problems with the HU101 keys and also HU64 etc.
    The M5 clamp is working much better.
    Almost no problems in the daily cutting.
    Only thing is the HU66 plastic key.
    I am not able to do these anymore, with the M5 clamp.
    (Maybe something I am missing, in the menu).
    But have other machine ready, which sorts these out.
    It is possible to swap back to the M2 clamp.
    But needs several minutes with adaption sensing etc.
    So I try to avoid this.
    Since its already working good, with the M5.
    I am using both clamps - the M5 is better for most keys, but some just won't hold on the b side (some Kia blade for instance) but both clamps have cons en pros... the latest updates did not improve but gave me more bugs (sometimes losing connection with the key tool max , some weird deep cuts leaving too little material etc.) - I was happy with it as it was but after so many urgent update messages still did and regret it now. Hope the update of last week fixes some bugs (they had new firmware and I think within a week another). What also occured to me was that since a month or so the cutter snapped at times . Used the 1.5 and since had the speed turned back on movement en rotations to max... went better but even then sometimes had it snap. Same keys as before. Now using 2.0 cutter and that's ok but cannot use it for all keys (HU162 for instance).
  3. #1923
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    relly bugs me this condor menu on screen
    yes i know can use phone but like to use screen
    example if i want to duplicate a hu101
    you would think it would be in menu but no it changed a while back and named it something else
    why cant they have it as a silca reference like most machines ?
    its on the phone app ok but not on the machine
  4. #1924
    Apr 2014
    hi guys, i am trying to assist a friend with a Condor XC Mini. On start up the motor would only move a short distance then stop. I attempted to do a self test and would get an error code 54. Has anyone come across this error? I would appreciate all assistance. Thank you.
  5. #1925
    szengen's Avatar
    Jan 2017
    Check the wires(tapes), from the motor, matry,c to the motherboard,under in the flow of movement they like to break
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  6. #1926
    Autronico2's Avatar
    Jan 2021
    Italia
    Guys, is there a list where I can see what type of key it has based on the car?
    For example, on most Fiat I find the SIP22
    Press Thank You + Reputation = Password
  7. #1927
    Apr 2022
    Germany
    Quote Originally Posted by Autronico2 View Post
    Just download the xhorse app and then open it, go to key cutting machine, then select vehicle database, select brand and model, in some cases you can select year of production and then you have the blade…
    All is free… and I guess that you have smartphone…
  8. The Following User Says Thank You to wuza For This Useful Post:
    Autronico2 (1st February, 2025)
  9. #1928
    Autronico2's Avatar
    Jan 2021
    Italia
    Quote Originally Posted by wuza View Post
    Thanks for replying, I couldn't find it.
  10. #1929
    Apr 2016
    Quote Originally Posted by trinicolin View Post
    Had a similar problem. Check wiring... But also check the sensors. Take the sensor from the visor and replace one that's faulty.
  11. The Following User Says Thank You to alkaskad For This Useful Post:
    trinicolin (5th February, 2025)
  12. #1930
    auto techniek's Avatar
    Mar 2017
    Any idea if xhorse xc plus2 cutting machine can be blocked.
    I ve just bought one new never used and has been stolen from my shop.
    Verstuurd vanaf mijn CPH2359 met Tapatalk
  13. #1931
    P&D's Avatar
    I would say yes if you have the serial number
    Im sure when I got mine I had to register my email & phone number and they where linked to the serial number
    even if you register on your mobile app or use the display on the machine, you have to register the machine to your account
    which you have to register/link the machine to there sever.
    Good luck pal
  14. The Following User Says Thank You to P&D For This Useful Post:
    auto techniek (12th February, 2025)
  15. #1932
    Apr 2022
    Germany
    Just wondering if anyone figured out how to cut BMW F series HU127 keys with XH.
    One side can be done, but the other side no chance.
    Sometimes the blades can be removed from blade holder (top of the key) and cutting is very easy.
    But sometimes blade holder and key blade are fixed with small pin on the side and 1 side can be done, but the other side no chance.
    Tested with M2 and M5 clamps and results are the same. Also tested universal key duplication and same thing…
