Page 15 of 125 FirstFirst ... 510111213141516171819202565115 ... LastLast
Results 211 to 225 of 1932
Hybrid View
    Quote Originally Posted by MaxMin View Post
    it is have difference with this two blade?
    i cut this BE key blade with xc-mini but not open door,i see condor not 100% cuting BE blade
    in picture ori nec key and be key
    with NEC to NEC blade i not have problem, all is ok
    Cut on hu64-3. Check blade size and input cuts manually. The angle from the first cut to the tip is different based on the length. Will work in the lock
    Sent from my SM-G930W8 using Tapatalk
  2. The Following 2 Users Say Thank You to dmp For This Useful Post:
    MaxMin (17th March, 2017), obdmaster (17th March, 2017)
  3. #2
    Jan 2016
    can anyone shed any light on cutting a silca EU21p to key number it is used on a motorhome
    Is this possible on my condor tool or is this not classed as an automotive key
    cheers in advance
    rob h's Avatar
    May 2011
    Quote Originally Posted by Romney1 View Post
    cheers in advance
    Is it a dimple key: then no.
    Otherwise you can creat a custom key file.
    Jan 2016
    No its not a dimple . Milling style im not sure how to create a file as i dont have the measurements of
    the depths as all i have is a key number and instacode doesnt list any thing
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    all blades from latest BE key type, on your picture right sample i cut as HU64-3 with function "cut by bitting"
    and from all orig HU64 blades i read the code with my eyes only, because it is more faster then put the blade to Condor and await for his decoding
    for example this blade is from older black plastic case Year 2001-2006 models and have code 2122455422 understand now ???
    but i use latest BE key and choose HU64-3 and write this code, what i read with my eyes manualy and cut with function "cut by bitting"
    till now all my cutted blades working in lock at first attempt...
    many thanks to friend kevfield
  7. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    AndyCZ (6th April, 2017), MaxMin (22nd March, 2017)
  8. #6
    Jan 2017
    USA ����
    milling looks shorter on be key
    is the key going in the lock all the way???
    take door lock out of door and check
    long t20 or t25 is needed
  9. The Following User Says Thank You to sleepyrz For This Useful Post:
  10. #7
    AndyCZ's Avatar
    Jan 2014
    EU
    NE78 not cut completely
    If I helped you know what to do..
  11. The Following User Says Thank You to AndyCZ For This Useful Post:
    rob h (17th March, 2017)
  12. #8
    rob h's Avatar
    May 2011
    Quote Originally Posted by AndyCZ View Post
    If you look close at the shoulder, you see the little differences.
    You did not place or calibrate correct.
    Check setting, if cutter diameter is correct!
    The cutter missed your key tip!
  13. #9
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by rob h View Post
    both keys tight to that shoulder as machine show on picture
  14. #10
    rob h's Avatar
    May 2011
    Did you measure the tip to shoulder lenght?
    The cuts need to be further back to the shoulder.
    If all fails, start the cutting, and pause after the calibration.
    Then place the about 1 mm towards tip.
  15. The Following User Says Thank You to rob h For This Useful Post:
    Jobeso66 (16th October, 2017)
  16. #11
    AndyCZ's Avatar
    Jan 2014
    EU
    Rob h you will not fix the blade in 1-2mm edge
  17. #12
    rob h's Avatar
    May 2011
    I see, you have a mini Condor.
    The clamp is different from the master condor.
    If the settings on your machine are correct, and you have choosen the correct clamp and cutter.
    Then it could be the key file.
    There is a keycutsomtool for the mini condor.
    You could create your own key file and load it by usb.
    It is good to know how to use this customkeytool. Takes about 5min max.
    There are probable a few more of these keys that give you troubles.
    Or they dont excist yet.
    And waiting for updates, is not a option for me.
  18. The Following User Says Thank You to rob h For This Useful Post:
    AndyCZ (17th March, 2017)
  19. #13
    Has anybody else had a problem loading the custom key files? I have the big condor and used the same software to update the software about a year ago, it connects to the machine and says they were able to synchronize but I can't find my custom key files anywhere.
    Should I try to do it with a different computer or do the files not end up with the manufacturer I selected?
  20. #14
    rob h's Avatar
    May 2011
    Hello Dmp,
    My Condor is still giving me the screen calibration problems.
    So i can not test this right now. But i have loaded files before.
    My machine runs on the latest software, that might be neccecary.
    I have recieved the mini condor 1.1.0 custom key tool from support.
    Butt have troubles uploading it for you guys. I will try that later on the mini condor thread.
  21. #15
    Hello Dmp,
    I believe I have the latest software (checked online and says up to date as well).
    I'll play around with it a bit more this weekend and see if I can get them to load.
