Page 16 of 129 FirstFirst ... 611121314151617181920212666116 ... LastLast
Results 226 to 240 of 1932
  1. #226
    Quote Originally Posted by rob h View Post
    Hello Dmp,
    My Condor is still giving me the screen calibration problems.
    So i can not test this right now. But i have loaded files before.
    My machine runs on the latest software, that might be neccecary.
    I have recieved the mini condor 1.1.0 custom key tool from support.
    Butt have troubles uploading it for you guys. I will try that later on the mini condor thread.
    I believe I have the latest software (checked online and says up to date as well).
    I'll play around with it a bit more this weekend and see if I can get them to load.
    Sent from my SM-G930W8 using Tapatalk
  2. #227
    Jan 2016
    ok now I have the custom file how do I work out the cuts from my key number instacode doesn't list this blank
  3. #228
    obdmaster's Avatar
    Never never land
    I have a condor mini , great machine does anyone have the latest software link to update machine? Only problem I've had is cold weather and runners sticking threw lack of use, just a little wd40 job done. Fantastic machine just would like latest software download link. Thanks again for all replies
    You need every tool in the book, to do this auto locksmith job.
  4. #229
    Moderator
    PremierD's Avatar
    Jun 2009
    Cold weather .... when did you move to Scotland mate ............
  5. #230
    Jan 2017
    USA ����
    Quote Originally Posted by Romney1 View Post
    Measure them......
  6. #231
    rob h's Avatar
    May 2011
    Here are the measurements
  7. #232
    rob h's Avatar
    May 2011
    http://condorkeycutting.blogspot.nl/
    I have the V1.1.0 but can not seem to get it uploaded here.
    V1.1.0 is with custom key tool for the mini Condor.
    Quote Originally Posted by obdmaster View Post
  8. The Following User Says Thank You to rob h For This Useful Post:
    paul_12345 (19th March, 2017)
  9. #233
    anyone got XC-002?? seems bit overpriced - guess main advantage is the extra token for MB.
  10. #234
    Jul 2015
    Did you have problem with decoding SIP16 (Alfa)?
    Otherwise cutting is OK, decoding is total wrong.
  11. #235
    Quote Originally Posted by gokart View Post
    upload a video... also if you cut a key then decode straight away does it still decode wrong?
  12. #236
    Jul 2015
    I tried with two original keys what I cleaned before decoding. The reading pin touched the keys at the correct positions however all value was far from the correct value.
    I was in hurry I hadn't more time to play with it. I will try to decode the new key next time.
  13. #237
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by MaxMin View Post
    it is have difference with this two blade?
    i cut this BE key blade with xc-mini but not open door,i see condor not 100% cuting BE blade
    in picture ori nec key and be key
    with NEC to NEC blade i not have problem, all is ok
    Attachment 436071
    all blades from latest BE key type, on your picture right sample i cut as HU64-3 with function "cut by bitting"
    and from all orig HU64 blades i read the code with my eyes only, because it is more faster then put the blade to Condor and await for his decoding
    for example this blade is from older black plastic case Year 2001-2006 models and have code 2122455422 understand now ???
    but i use latest BE key and choose HU64-3 and write this code, what i read with my eyes manualy and cut with function "cut by bitting"
    till now all my cutted blades working in lock at first attempt...
    many thanks to friend kevfield
  14. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    AndyCZ (6th April, 2017), MaxMin (22nd March, 2017)
  15. #238
    Jan 2017
    USA ����
    How can I cut hu100 10 cut?
    It seems it only has the 8 cut in the menu
  16. #239
    rob h's Avatar
    May 2011
    Hu100 Opel GM uses only 8 cuts.
    So you realy need 10?
    Quote Originally Posted by sleepyrz View Post
  17. #240
    Jan 2017
    USA ����
    Yes in usa all of the SUV use the 10 cut for hu100 key
    I was told just now that they are working on it
    Samic was at AKS 3 weeks ago and they gave him the list of issues to work on
