Page 17 of 125 FirstFirst ... 712131415161718192021222767117 ... LastLast
Results 241 to 255 of 1932
Hybrid View
    Sep 2017
    Quote Originally Posted by sleepyrz View Post
    Alright I think I got that figured out now too
    Were you able to to cut hu100 10-cuts without any problems , ? I found a solution recently playing with cóndor mini
    Jan 2017
    USA ����
    Quote Originally Posted by Jobeso66 View Post
    yes i just make a custon key file for hu100 10 cut
    and cut by input direct bitting
    or trace with hu100 8 cut and figure out last two cut then use custom key filefor 10 cut
  3. The Following User Says Thank You to sleepyrz For This Useful Post:
    Jobeso66 (4th November, 2017)
    Mar 2009
    I have recently purchased an XC-mini, and I'm pleasantly surprised by it. Its much better than I was lead to believe!
    Has the Renault keycard blade cutting been fixed, or is there a solution by making a custom file? It cuts the opening V incorrectly as mentioned earlier in this thread. I tried making a custom file, but dont know how to correct the opening V part of the key specification.
    Also, is the custom file specification available anywhere ? It would encourage alternative software if this were available along with the communication specification over USB.
    Thanks.
    Oct 2017
    Quote Originally Posted by madaxe View Post
    Thanks.
    It is ready next update.About how to make a custom file,following file for reference,hope that can help you a little.
  6. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    kostas (3rd November, 2017)
    Jan 2017
    USA ����
    Omg I am having the same problem I had on the Chrysler key where it would miss the bitting on the Nissan da34 now........
  8. #6
    May 2013
    Hi there.
    I am having problems with the TOY41R (TOYO9). The machine tells you to line up the blank according to the shoulder.
    However the machine seems to be sent to the wrong position for all the bits. It cutting too much to the shoulder of the key. All cut are way too back on the key. It's about 1 position too back. I had to then manually cut a section of the shoulder off and trim the front of the key and it works perfects on the lock then.
    I tried KEY DECODE with a cut key and see that it is doing the same. The position is off. Also you will notice that on TOY41R the machine does not sense the tip of key as it would do with other keys such as TOY43.
    Could somebody please check if their machine also having this problem on TOY41R (TOYO 9).
    Another problem is the HONDA HON66. When duplicating the keys it is fine but when cutting according to wafers from locks then I seem to have a problem. The last wafer is usually a full size after which would be for Axis A and AXIS B. However it seems that the Machine doesn't count this wafer and also cuts the key then too Front.
  9. #7
    rob h's Avatar
    May 2011
    Always mention what type of Condor you have, 007 master, or mini!
    What happens if you choose silca DH4R?
    The toy41r is a shouldered key, the toy43 not, that is why it does not probe the tip.
    For now, a solution might be, creating you own files with the custom key tool.
    A trick, start the machines cut session, then after calibrating, pause session, and adjust the blanks position.
    Or even before calibration, because this one does not probe the tip.
    Quote Originally Posted by obeids View Post
    Hi there.
  10. #8
    May 2013
    Quote Originally Posted by rob h View Post
    Sorry I have the Condor Mini K3.
    When I press the pause it cancels the cutting unlike other keys which pause and you can swap out keys or whatever.
    If I create a custom file, would it be saved on the machine or would I have to connect the laptop everytime I want to cut that time key?
  11. #9
    rob h's Avatar
    May 2011
    Any custom files remains in your machine, until you update.
    After any updates, you just need to synchronize 1 time using your customfiles.
    Did you try to cut it as a DH4R?
  12. #10
    May 2013
    I tried with the DH4R to decode and still the cuts are too much to the shoulder.
  13. #11
    Jul 2015
    HU136 isn't in the list. Have you already tried to cut it somehow with Condor?
  14. #12
    rob h's Avatar
    May 2011
    Quote Originally Posted by gokart View Post
    Look on instacode for a similar key, with Same seizes and cuts.
    Someting Like va102 ne72
  15. #13
    Jul 2015
    I have already compared with VAC102 and NE72. These have 6 cuts while HU136 has 8 cuts according to Silca catalog.
  16. #14
    siyadk's Avatar
    Dec 2012
    has anyone received any update on condor mini.. i believe there was hasn't been an update for almost more than a year. Can anyone confirm??
  17. #15
    Jul 2015
    Quote Originally Posted by siyadk View Post
    You are right.
