Page 22 of 129 FirstFirst ... 1217181920212223242526273272122 ... LastLast
Results 316 to 330 of 1932
  1. #316
    Someone try with last update emergency key laguna/megane card?
  2. #317
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by Brat View Post
    You still need a spacer to handle with them, i tried one yesterday :/
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  3. The Following User Says Thank You to lpf01 For This Useful Post:
    Brat (16th May, 2017)
  4. #318
    AndyCZ's Avatar
    Jan 2014
    EU
    not fixed.
    It's not about spacer. The beginning of the cut must be wider.
    If I helped you know what to do..
  5. The Following 3 Users Say Thank You to AndyCZ For This Useful Post:
    Brat (16th May, 2017), PierreTheron (19th July, 2017), rm23 (19th May, 2017)
  6. #319
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Who not yet did update CONDOR XC-Mini to latest update, is available new update for serials KM03xxxxx new update number 4.0.1
    added instead Auto Car keys newly standard housing keys type too....
    many thanks to friend kevfield
  7. The Following 4 Users Say Thank You to daxxer For This Useful Post:
    CaioW (22nd May, 2017), fytfh (22nd May, 2017), PremierD (22nd May, 2017), sleepyrz (22nd May, 2017)
  8. #320
    Jan 2017
    USA ����
    Hu64
    There are 3 of them
    How do I know which one to use????
  9. #321
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    show screen what blade you want to duplicate or cut
  10. #322
    Jan 2017
    USA ����
    I always use hu64 when I decode door or trunk and it works fine for me
    But maybe I dont run Into the right car yet where it doesn't work
    Is there a general rule to know which one to pick?
  11. #323
    Jul 2015
    I have cut key only for W168 so far I used HU64. I'm also curious about the other options.
  12. #324
    Quote Originally Posted by gokart View Post
    Difference is length of blade. Should show on the screen and can measure what you have. Different length blades can be used on same lock if cut properly
    Sent from my SM-G930W8 using Tapatalk
  13. The Following User Says Thank You to dmp For This Useful Post:
    gokart (23rd May, 2017)
  14. #325
    Jan 2017
    USA ����
    the only difference i see is the distance from the tip to the first cut
  15. #326
    Quote Originally Posted by sleepyrz View Post
    Yes and overall length (related of course)
    Measure the key blades to be sure
  16. #327
    Jan 2017
    USA ����
    ok but what if i am originating a key
    i have nothing to reference to know which one to use
  17. #328
    Measure the blade you're cutting on then. Same idea
  18. #329
    Jul 2016
    How are you guys cutting the Prius Emergency Key on the condor, all this time I never ran into cutting he Prius key and it was too short to make it to the second line from the top
  19. The Following User Says Thank You to iHenry3 For This Useful Post:
    mikroel (26th May, 2017)
  20. #330
    Jul 2016
    Today I cut a hu64 after updating and the key was hard to turn, I calibrated and everything possible. Never had this issue before !!!
