Page 29 of 129 FirstFirst ... 1924252627282930313233343979 ... LastLast
Results 421 to 435 of 1932
  1. #421
    Moderator
    PremierD's Avatar
    Jun 2009
    Perfect for copying Benz emergency key
  2. The Following User Says Thank You to PremierD For This Useful Post:
    louis21 (3rd August, 2017)
  3. #422
    Quote Originally Posted by hipolitogt View Post
    I'm trying to find this option and I think it doesn´t have it. I have mini condor 4.0.1 km03
    Enviado desde mi SM-G955F mediante Tapatalk
    Found It and work ok with Megane card emergency key
  4. #423
    Jul 2016
    Last week I tried cutting Toyota Avalon Emergency Key, I put in the code series which was 80000 series but it wouldn't cut the key probe would be to high, look as if it looking to cut lxp90
  5. #424
    Jan 2017
    USA ����
  6. The Following User Says Thank You to sleepyrz For This Useful Post:
    louis21 (10th August, 2017)
  7. #425
    lidons's Avatar
    Feb 2011
    /////////////error
    excuse my English, is the best.
  8. #426
    rob h's Avatar
    May 2011
    Same problem that i have had.
    Probe whas to high, i lowered it, and recalibrated.
    I placed a 0.75 mm plate underneed the Toy40 emergency key, then clamped it.
    A lishi master keyblade works fine, it does Not need to be the total full 3mm.
    Quote Originally Posted by iHenry3 View Post
  9. #427
    PierreTheron's Avatar
    Centurion,South Africa
    Keys Code is ok, read with silca and same Code, problem is initial cut, not the same check photo, middle key is original, the other cut by mini condor. Recut by silca key cutter and now works.
    My self made key file for these keys cut key correctly .Exact as middle photo .
    tested on all different key blades i had in stock and working perfect.(original and more narrow and with Sharp point)
    must use 2.5mm cutter and .8mm spacer made from plastic cellphone card..
  10. The Following 2 Users Say Thank You to PierreTheron For This Useful Post:
    hipolitogt (12th August, 2017), p1et (23rd August, 2017)
  11. #428
    Quote Originally Posted by PierreTheron View Post
    Can you send your key file to upload to mine? And also, can you post a photo of your self made spacer?
    Thanks!!!!
  12. #429
    Jan 2017
    USA ����
    does anyone know if the problem with the cutter hitting the tibbe key adapter has been fixed
  13. #430
    Thanks!!!!
    Post 364 mate
  14. #431
    Post 364 mate
    Thanks!!!
  15. #432
    GB
    Dears
    we bought 12 Condor XC-007 key cutting machines , we have some problems in some machines , we need the contact details of the factory or technical department please
    we are in Shenzhen now .
    regards
  16. #433
    Jan 2017
    USA ����
    ok two things
    does anyone know if the problem with the tibbe key has been fixed where the cutter hits the clamp at the end?
    and also what is the m3b jaw for?????????????
    m3a is clearly for tibbe keys
  17. #434
    Greece
    m3b jaw is for sx9 but not cut ok the side cuts
  18. #435
    May 2017
    hit the clamp at the end?have no impression of it,when is it reminded?
