daxxer (4th September, 2016)
daxxer (5th September, 2016)
Hi there
Recently got the Condor Mini.
Seems good. However if the dust cover could have been designed a bit away from key it would've been nice. Currently the problem is most keys will touch on dust cover when cutting. Some key like VW Flip key cannot let the cover be closed. So if cover is open then what is the purpose of dust cover because dirt goes everywhere.
The database needs amended .. to show where in actual fact you put the key but its common sense really, it cannot clamp firmly if it is not a uniform width so either file the high spot of the key .. or do as suggested move it further back![]()
purdy (23rd September, 2016)
hi
i have never succeed to cut buy code or copy HYUNDAI / KIA HYN14R or HYN14 profile every time there different between Right and left side. i hope can rectify this .
Little tip for all users.
I have machine with SN starting with KM02.
To cut keys HU92 BMW need to be in 1.00MM, when you select HU92 the device will ask you to chose between Land ravor and BMW, Land Rover came with 1.00mm and BMW with 1.25mm, if you try to cut with 1.25mm the key will not turn.
I have proved with 4 different machines and 3 different cars.
Hi need help update the car data base in this software all cars are 0 how can i import the key info for each car![]()
NO ADVERTISING PLEASE
daxxer (12th October, 2016)
[QUOTE=Nassreddine84;2859528]Hi need help update the car data base in this software all cars are 0 how can i import the key info for each car /QUOTE]
mate,this function for customer define key that the key without any detailed information currently.each key data need to measure by yourself.
the attachment file is sample about define key,mainly Chinese vehicles.(extract the file,'Import' to key data customize tool software)
bbopel (20th October, 2016)
Xhorse Condor XC-Mini video download link(include how to calibrate & how to use M3 clamp cutting keys)
if your machine still not work well/find bugs/good advise,please post here/PM me.
Guy's long time not much feedback from you ???? I think about buying XC-mini. Is it bug fixed yet ??
daxxer (19th October, 2016)
I haven't no any problems with Condor XC-Mini
cut keys blade HU64-3 without any problems in first attempt![]()
many thanks to friend kevfield
Just got a new mini. So very new to this. Been very successful up till now. Tried to decode a Renault megane emergency key Card type. Renault-megane-2003- Condor checks the clamp position ok then goes looking for the tip of the key but misses the tip with the prob going down the middle of the cut for 5mm then backs off as it thinks no key is in the clamp. Is it operator error or a bug. Look like the probe is not low enough to bump into the key tip. Other than this I'm very happy.
Sent from my iPad using Tapatalk
Add life to your days not days to your life
P
