Page 51 of 129 FirstFirst ... 41464748495051525354555661101 ... LastLast
Results 751 to 765 of 1932
  1. #751
    Jan 2017
    USA ����
    Quote Originally Posted by bid178678 View Post
    I just get a brand new condor XC mini and updated to 5.0.4
    I got a problem with GT15 Piaggio keys, the key is too small to reach the shoulder stop of the m1 jaw.. see pictures.
    So no way to cut the key directly.
    I was able to cut those keys with my chinese miracle A7 ...
    Any ideas to solve this issue?
    OlivierAttachment 524106Attachment 524107
    yes same way i did it
    cut off head of key
    stick in blade and cut
    duplicate key onto another one with head
  2. The Following User Says Thank You to sleepyrz For This Useful Post:
    bid178678 (26th April, 2018)
  3. #752
    Jul 2015
    I've not cut GT15 with the latest update yet. Has it still cut the tip of the key?
  4. #753
    Jan 2016
    Quote Originally Posted by sleepyrz View Post
    cut off head of key
    Yes this is a solution but i buy XC to avoid the manual copies that are not enought accurate .
  5. #754
    Jan 2016
    Do you a contact for Condor XC after sale ?
  6. #755
    Jan 2013
    this bitting code must be 33224311?
  7. #756
    Oct 2015
    Quote Originally Posted by fytfh View Post
    Almost correct - sholud be 33224211 (exist in series 1-6000, number 2259)
  8. The Following User Says Thank You to klesk1986 For This Useful Post:
    fytfh (28th April, 2018)
  9. #757
    Oct 2017
    Samic Why condor mini cant decode lexus toy48 and toy40 keys?
    i mostly cut lexus keys and i cant decode it by condor mini..
  10. #758
    Apr 2015
    Quote Originally Posted by Asifmehmmod1 View Post
    friend, Condor MINI usually decode/cut key as the standard thickness 3mm, if the key is single side(thickness no more than 3mm, such as 2.5mm or 2mm)
    then you should add a shim(such as business card) under the key, let the key thickness more than 3mm(around 3mm).
  11. The Following 8 Users Say Thank You to Samic For This Useful Post:
    AndyCZ (6th May, 2018), bursuc (14th March, 2019), doctore (29th April, 2018), Faraday (29th April, 2018), Jobeso66 (12th September, 2018), PremierD (28th April, 2018), rm23 (7th May, 2018), yugo45 (28th April, 2018)
  12. #759
    Jan 2017
    USA ����
    He finally passes by and that's what we get.......
    Hey samic where is m4 jaw
    I got some keys I'd like to be able to cut
  13. #760
    Moderator
    PremierD's Avatar
    Jun 2009
    Then go to Timpsons you plank .....
  14. #761
    Oct 2017
    Thanks for quick reply..
    i was able to decode toy40 and toy48 only 4-4 cuts. with 8-8 cut it still dont decode ..(have latest sw version of condor)
    but if i manually put the bitting it cut the key.
  15. #762
    Aug 2016
    Anybody decode citroen sx9 keys with condor mini?I was trying to duplicate this key but condor start the process and after 3 second stops.
  16. #763
    Apr 2015
    Quote Originally Posted by tkmotors View Post
    currently SX9 and FO21 keys cannot support decode function, just enter bittings then cut directly.
    we will add SX9 decode function, engineer still working on that.
  17. The Following 6 Users Say Thank You to Samic For This Useful Post:
    AndyCZ (6th May, 2018), Carkeysa (4th May, 2018), darkoman (3rd May, 2018), Faraday (3rd May, 2018), rm23 (4th May, 2018), tkmotors (3rd May, 2018)
  18. #764
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Quote Originally Posted by Samic View Post
    have you tried contact instacode samic
    and get it integrate with this program
    am sure you guys sell enough machines that would befit all parties
  19. #765
    USA
    Quote Originally Posted by iHenry3 View Post
    How are you guys cutting the Prius Emergency Key on the condor, all this time I never ran into cutting he Prius key and it was too short to make it to the second line from the top
    Has anyone figured out a good workaround for this? The pullout 2004-2009 Prius emergency key is too short to reach the 2nd line like a TR47 blank.
    Perhaps Condor can modify the software to allow you to "move" the line to position 3 or 4 from the top via software for keys like this?
    I know I can cut onto a TR47 then copy with a side by side duplicator but it would be nice if my $3000 machine can do it directly.
