Page 52 of 129 FirstFirst ... 242474849505152535455565762102 ... LastLast
Results 766 to 780 of 1932
  1. #766
    Mar 2009
    Quote Originally Posted by baboonia View Post
    The pullout 2004-2009 Prius emergency key is too short to reach the 2nd line like a TR47 blank.
    I agree its a real PITA. dont know any workaround. It should be real simple to fix. I mentioned it months ago on this thread, then to xhorse people I saw at a show in UK, and they still dont do anything to fix this. Makes me wonder if the people we get to speak to dont have any avenue to developers, or they just dont care. TOY43 10 cut blade, XHorse please fix !
  2. The Following User Says Thank You to madaxe For This Useful Post:
    royalkey (7th May, 2018)
  3. #767
    In EEP
    HI can you solved problem with megane emergencz key . The key is located to low sow condor cannot find the key and does give a error...................
  4. #768
    wissamshaat's Avatar
    Oct 2017
    france
    Quote Originally Posted by vasa View Post
    for the megan emergency key you have to put somthing under the blade to cut
    like a piece of credit card and it will work
  5. The Following 2 Users Say Thank You to wissamshaat For This Useful Post:
    musti418 (7th October, 2018), vasa (7th May, 2018)
  6. #769
    Apr 2015
    Has anyone figured out a good workaround for this? The pullout 2004-2009 Prius emergency key is too short to reach the 2nd line like a TR47 blank.
    Perhaps Condor can modify the software to allow you to "move" the line to position 3 or 4 from the top via software for keys like this?
    I know I can cut onto a TR47 then copy with a side by side duplicator but it would be nice if my $3000 machine can do it directly.
    Thanks for your feedback in detail, next week we will fix TR47 align issue and make an update.
  7. The Following User Says Thank You to Samic For This Useful Post:
    madaxe (10th May, 2018)
  8. #770
    Jul 2015
    Quote Originally Posted by Samic View Post
    Please, revise GT15 too because condor cuts the tip of the key.
  9. #771
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Looks like xhorse made XC-MINI II https://drive.google.com/file/d/1BJ5...vl_PLX3l8/view
  10. #772
    Jan 2017
    USA ����
    Well it's slower.....
    9k rpm the old is 10k rpm
    You can get a battery adapter for the xc mini that's cool I guess.......
    M4 clamp!!!!!
    I need this!
  11. #773
    Jan 2017
    USA ����
    Pics for you
    Battery says it will cut about 40 keys per charge
  12. #774
    Jan 2018
    CA, USA
    i have a question, what settings do you have your cutter? right now i have mine at default which i believe it is medium speed, and 2 pass cuts. does anyone have issues with single pass cuts?
  13. #775
    Jul 2015
    Quote Originally Posted by cniksor View Post
    The less cutting depth in any direction and more passes provide better surface quality and accuracy. This type of cutting method also increases the lifetime of the milling tool.
  14. #776
    USA
    This might be a stupid question but which Condor web site is the official company site (not a reseller) and where can I download the latest official PC software and latest machine software to keep my Condor Mini updated? Many of the links I find online are questionable source and report viruses attached.
  15. #777
    May 2013
    Look for the Xhorse update kit. It will automatically download from the servers latest version and update your device....
  16. #778
    May 2013
    They seem to have made a new machine but forgot this stuff which maybe they can do in Version 3 then...
    1) Space between cover and key should be bigger.... Many keys with casings like VW flip key will not allow you to close the cover . X6 wins in this point.
    2) They should make the screen with adjustable angle. Many time the machine is on a higher / desk and it's then difficult to operate and see what's on the screen.
    3) Mounting support - to make it easier when mounting the machine on a Mobile unit as you don't want it flying around in the back of your VAN....
  17. #779
    Jun 2013
    Quote Originally Posted by obeids View Post
    The release should be in mid August regarding the swimming machine.
    I guess this one would work out fine with the new Pad which is on its way very soon from this company.
    Quite integrated then. Using pad to do programming. And sending away info with Bluetooth (or USB), about cutting in one piece of item.
    But I guess it is possible to use any other pad/mobile phone or PC as well.
  18. #780
    Jun 2016
    Default xc-mini plus
    Quote Originally Posted by Weasel3 View Post
    Condor xc-mini plus, saw it in the 5.18 Chinese locksmith annual meeting.
    it improves in the first 2 points as obeids guess. I am not sure the 3rd point.
