Page 53 of 127 FirstFirst ... 343484950515253545556575863103 ... LastLast
Results 781 to 795 of 1900
  1. #781
    Jun 2013
    Quote Originally Posted by crazylou2017 View Post
    Condor xc-mini plus, saw it in the 5.18 Chinese locksmith annual meeting.
    it improves in the first 2 points as obeids guess. I am not sure the 3rd point.
    I was not totally aware of all the updates on the Condor Mini.
    I was babbling about the Dolphin, with no screen integrated
  2. #782
    Jul 2015
    What changed in v5.0.8 comparing to v5.0.4?
  3. #783
    Mar 2009
    There is now a v5.0.9, also with no info about whats updated. I realise it must be time consuming, but come on XHorse, you should really say what has been fixed, and announce the updates. how about a mailing list for the updates ? Particularly if you want to be a quality developer of tools.
    I notice that the TOY43 key clamp position has been moved, hopefully this will fix the Prius emergency key problem mentioned earlier in the thread. Had the update been announced, I'd have installed it and tested it on a vehicle today.
  4. #784
    Jul 2015
    Yes, I updated my machine to v5.0.9 last week. It still cuts the tip of the GT15.
  5. #785
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I have problem with XC-mini and M1 clamp try to make key for ssangyong actyon decode ok but machine cut to much
    I did try universal and here problem even bigger decode ok machine cut 1 part ok but when move to the other side
    it lower cutter in the middle of the key and destroy it ( will update post with pictures)
  6. #786
    rob h's Avatar
    May 2011
    Check cutter diameter in settings, and then calibrated.
    And make sure that the key is clamped solid.
    Quote Originally Posted by Faraday View Post
  7. #787
    USA
    Quote Originally Posted by obeids View Post
    Look for the Xhorse update kit. It will automatically download from the servers latest version and update your device....
    Can someone please post a link to the official factory download site for latest Condor software...
  8. #788
    Jul 2015
    Quote Originally Posted by gokart View Post
    Great. It's impossible to cut FO21 with this version. It breaks the probe, scratches the clamp FO21. The tray hits the machine harshly. Well done.
  9. The Following User Says Thank You to gokart For This Useful Post:
    kleidaras (31st May, 2018)
  10. #789
    Check the length of the gt15 blade
  11. #790
    Faraday's Avatar
    May 2012
    Quote Originally Posted by rob h View Post
    Key is clamped solid cutter is ok.
  12. #791
    Jul 2015
    Quote Originally Posted by paul_12345 View Post
    It's OK. The key was made by Errebi.
  13. The Following User Says Thank You to gokart For This Useful Post:
  14. #792
    auto techniek's Avatar
    Mar 2017
    Can somebody decode this two blades pls.
  15. #793
    rob h's Avatar
    May 2011
    34331242
    and your other FORT Locker Key = 3211234343
  16. The Following 3 Users Say Thank You to rob h For This Useful Post:
    auto techniek (2nd June, 2018), M3L3R (10th June, 2018), z786 (3rd June, 2018)
  17. #794
    Mar 2017
    31344423
    34331242
    Thanks mate.
    Question about the second picture:34331242. If you look good at the tip it is not like casual hu66. Whatever i did i can t cut it good.
  18. #795
    rob h's Avatar
    May 2011
    Tip off second key looks fine.
    Same as always
