Page 5 of 127 FirstFirst 123456789101555105 ... LastLast
Results 61 to 75 of 1905
  1. #61
    Norfolk england
    Quote Originally Posted by paul_12345 View Post
    its probably not the probe being low enough but your key thats not high enough! these blades need spacers (unless the clamps are different on the mini)
    The reason is because although the top of the blade clears the clamp the cutter will be lower and would hit the clamp whilst cutting the tip of the key.
    Had a bash today. There is a small lip on the right side of the clamp. If the key is clamped under this lip it reads is perfect. Same effect as shimming.
    Sent from my iPad using Tapatalk
    Add life to your days not days to your life
    P
  2. #62
    Norfolk england
    Hi all
    need to do SX9 keys were to buy clamp
    will it decode these too
    Samic can't find anyone with stock. There seems to be confusion with the New M3 clamp. Can you. Clarify please
    P
  3. #63
    Will condor mini be supported by instacode in any near future?
    I hope I can use it to make kwikset master keys generated by instacode.
    BR
  4. #64
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by purdy View Post
    Just got a new mini. So very new to this. Been very successful up till now. Tried to decode a Renault megane emergency key Card type. Renault-megane-2003- Condor checks the clamp position ok then goes looking for the tip of the key but misses the tip with the prob going down the middle of the cut for 5mm then backs off as it thinks no key is in the clamp. Is it operator error or a bug. Look like the probe is not low enough to bump into the key tip. Other than this I'm very happy.
    There is an adapter to make renault card emergy keys.. Its a piece of steel who have the correct high.. just put above the key.. you can read and cut perfectly.
    Quote Originally Posted by neverquiet View Post
    BR
    MiniCondor have instacode inside.. you can put your code and prove if the code is true or not.. or even if you dont have some cuts device will search all the posibles cut for you.
  5. The Following 3 Users Say Thank You to CaioW For This Useful Post:
    daxxer (15th November, 2016), neverquiet (14th November, 2016), purdy (14th November, 2016)
  6. #65
    Aug 2016
    can condor cut key if i received Mechnical Code from PSA server ?
  7. #66
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by MaxMin View Post
    if you have key code can Condor support on key database function
    many thanks to friend kevfield
  8. The Following User Says Thank You to daxxer For This Useful Post:
    MaxMin (15th November, 2016)
  9. #67
    Norfolk england
    hi all
    whats the latest soft for the condor mini im on 3.0.1?
    P
  10. #68
    Moderator
    PremierD's Avatar
    Jun 2009
    that is the latest ....
  11. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    purdy (21st November, 2016), Samic (24th November, 2016)
  12. #69
    Dec 2010
    Greetings, friends, can you put it in Spanish?
    Thank you
  13. #70
    May 2013
    Hi there Guys.
    I am having a problem with my Condor Mini.
    I was trying to cut a Hyundai Accent Key with HY18R / HY18. After decoding the Screen would become white and the machine wouldn't do anything.
    So I figured they might have an update for the machine.
    I tried updating and it kept saying COMMUNICATION WITH SERVER FAILED (5).
    Problem is now my machine is stuck on the bootup screen and I cannot use the machine.
    Any solutions guys?
  14. #71
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by jaelgti View Post
    Thank you
    Actualy there is an update with Spanish version, but the translation is bad.. have tested and dont work very well.
  15. The Following 2 Users Say Thank You to CaioW For This Useful Post:
    jaelgti (2nd December, 2016), Jobeso66 (6th October, 2017)
  16. #72
    Dec 2010
    [Quote = CaioW; 2902052]. Actualy hay una actualizaci?n de la versi?n espa?ola, pero la traducci?n es mala .. han probado y no funcionan muy bien [/ quote]
    Thank you very much
    The truth is that not necessary, it is a very intuitive machine
    I'm very happy with the machine
    regards
  17. The Following 2 Users Say Thank You to jaelgti For This Useful Post:
    CaioW (2nd December, 2016), Jobeso66 (6th October, 2017)
  18. #73
    rob h's Avatar
    May 2011
    Will there be a clamp for keys, other then automotive?
    Creating a new key in the database is possible with the update software.
    But the clamps are limiting some cutting depths.
    It would be great if i could use the machine for tubular key cutting, and some house Keys.
    I am very happy with the master cutter!
    Great tool, with potential!
  19. The Following 2 Users Say Thank You to rob h For This Useful Post:
    amigokola (4th December, 2016), kleidaras (3rd December, 2016)
  20. #74
    Jul 2016
    Finally got the XC Mini today, very nice setup with instacode. Been using the 3D Pro, time to see what this puppy got.
  21. The Following User Says Thank You to iHenry3 For This Useful Post:
    Nassreddine84 (6th December, 2016)
  22. #75
    Dec 2015
    Quote Originally Posted by iHenry3 View Post
    Hi henry can u ply explain about the 3D work thank u
    NO ADVERTISING PLEASE
