Page 71 of 127 FirstFirst ... 2161666768697071727374757681121 ... LastLast
Results 1,051 to 1,065 of 1900
  1. #1051
    Top Poster rojhat's Avatar
    Sep 2015
    france
    Quote Originally Posted by ROMIR View Post
    Hello
    After update to 5.2.1
    Now mini is totally dead
    Shows only 00000000C0000000
    Anyone encountered this situation?
    Contacted the seller but they are totally ignorant and unresposible.
    Their valuable response:Enjoy the weekend.
    Thnx
    hi put off disconect usb wait few min. after connect soft clear all data with repair tool . and finaly try old 5.17
    for me when i try 5.20 same error whith midle screen black and color after fex update . its ok
    Envoyé de mon SM-A605FN en utilisant Tapatalk
  2. #1052
    Jan 2016
    Hi can anyone tell me the lastest software for the xc 007 master series are updates still available or has everything changed to the mini type cheers
  3. #1053
    Jun 2011
    Just tested the HU162-10 and it’s not cutting the side cuts on the correct edge, not sure about the 9 or 8 but the 8 does still only have 4 depths
    Is there a way to get the data off the condor to modify and sort these problems?
    I’ve tried to make my own with instacode and load but it isn’t easy for the side cuts on HU162, I did make the new ford hu101 internal and works ignition fine but door lock only turns one way
  4. #1054
    Nov 2018
    I'm still having issues getting my XC-007 working. I just need to load the firmware back onto the machine, but it seems that the firmware doesn't exist on the xhorse server. Has anyone managed to reprogram the machine in this situation using an sd card or using data from their laptop/pc without needing access to data from server? I've had some help from a guy called Samic via Skype and he has remote controlled my laptop a couple of times, but as yet it isn't fixed. The machine has only cut a handful of keys in its life, and This must be a straightforward fix. The laptop update tool enabled me to wipe the ROM in the machine far too easily.
    I have been considering buying several key programmers from Xhorse, but this would put me off for life using them again if the machine is not recoverable. Has anyone else had this same issue in recent times? Thanks.
  5. #1055
    rob h's Avatar
    May 2011
    https://www.digital-kaos.co.uk/forum...ta#post2913023
    there should more of these files, newer version,
    it would be nice to have them here on D.K.
  6. #1056
    Greece
    Today i update my mini with Power Supply Adapter with Battery. Very nice update and very cheap!!!!
  7. #1057
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by kleidaras View Post
    Where can I find it?
  8. #1058
    Greece
    I bay it from 3dgroup. i dont know if have other now.
  9. #1059
    sdnatlst's Avatar
    Aug 2011
    England
    my condor doesnt seem to like the cold, i leave in the van sometimes and gets to 0C overnight in england, sometimes less
    gives errors when first decoding or starting, and "clonks" with motor movements a bit,
    self test motor movements a few times sorts the issue, what temperature should this machine cope with?
  10. The Following User Says Thank You to sdnatlst For This Useful Post:
    Jobeso66 (18th December, 2018)
  11. #1060
    ghostrider72's Avatar
    Jul 2012
    UK
    Does anyone cut HU135T key for Kia with Condor? Its not in Condors menu
  12. #1061
    Jul 2018
    CHINA
    Quote Originally Posted by ghostrider72 View Post
    is the new key for kia . ? try to with the k5 2016- , update you device to 5.2.1
  13. #1062
    Jul 2018
    CHINA
    Quote Originally Posted by sdnatlst View Post
    hi , for the machine , is better keep it more than 0℃ .or keep it in one place which air dry , dont make the machine freeze ,
  14. #1063
    Jul 2018
    CHINA
    Quote Originally Posted by zippy82 View Post
    yes , mini condor can cut the hu162t side , you need use the blank key or something to fix the hu162t key , also use the 1.5 mm cutter , do the calibration if has deviation of cutting , you can add that skype :xhorse-support 2 if anything you need ,
  15. #1064
    Jul 2012
    UK
    Quote Originally Posted by PerryZhang View Post
    Its updated already and still nothing
    No its not new one. Its 2012 Kia Venga UK model
  16. #1065
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Does anyone know the name of the keyblade for LR Freelander 2005?
    Should be NE38 but is not decoding properly.
