hello martin,
I have problems with one of the mini condor...stepper motors moves a bit and stop before cuuting key..I get error code 51 when I try to calibrate
hello martin,
thanks for reply!
what is the operating temperature for this machine?
axis will freeze once it started for 1 sec then sieze up!
i banged on the machine a couple times and all of sudden it started working..maybe key shavings stuck inside caused it!!
difference between mini and mini plus?
when will dolphin be released?
Hello
Did someone already bought and received the PLUS version - any comments?
Is it possible someone could make me a custom file for The original condor x007
For the MG 6 that uses the same hu66 as the vw ? I never understand how to imput the specs from instacode thanks in advance
i have M3 tibbe clamp, it does not cut right, it starts to cut half way up the fin on the tibbe blade, and goes all way to tip/clamp edge
it never starts at the bottom of the fin, like it should for cut number 1
there is no calibration method for M3 clamp, what do i do? anyone successfully cut tibbe on m3 clamp
i am on version 5.1.6, photo attach shownig first cut of my tibbe being half way up the blade
I had same issue with my clamp. Sent details to Samic. No response since 5 months now.
Im not sure it is a clamp problem, looks more like a calibration issue in the software?
It is clamp issue. Your key isn’t going deep enough inside
well thats rubbish then, i will contact my supplier of the clamp
that's why there is an adjusting bolt mate ... to adjust it to fit
sdnatlst (24th January, 2019)
It wont help mate. Its not going deep enough even with bolt removed. At least in my case
