Page 87 of 127 FirstFirst ... 3777828384858687888990919297 ... LastLast
Results 1,291 to 1,305 of 1900
  1. #1291
    Mar 2016
    South Africa
    Default kawasaki kw16 blade profile
    Hi anyone have a profile for condor xc-mini
    KAWASAKI KW16 Blade
  2. #1292
    HeXeN's Avatar
    Mar 2015
    I cannot cut VA2 from Megane III WHY?
    Cannot go by model, when I choose via Renault megane 2003- and adapter M2-C it cuts fuc...g wrong because can only open car, cannot close or opposite, cant remember.
    When choosing via blade type & M2-A it shows another bullshit. WHY?
    I have tried via all types of VA2 and all the same is one total shit & wrong for this type or model & year.
    Look at this picture.
  3. #1293
    Feb 2014
    It can't cut emergency blade - it never could. It's an old and common disease.
  4. #1294
    HeXeN's Avatar
    Mar 2015
    Quote Originally Posted by autoTkey View Post
    But I have cut Laguna III 2009 2 months ago and it worked ok with the door locks. Used M2-C
  5. #1295
    Greece
    Quote Originally Posted by HeXeN View Post
    The card you have on photo is not for megane3 blade. Is for Clio 3 key or aygo key etc. Not exist card for megane 3 or laguna 3 on mini.
    Στάλθηκε από το ATU-L21 μου χρησιμοποιώντας Tapatalk
  6. #1296
    HeXeN's Avatar
    Mar 2015
    Can SEC-E9 cut more types than mini?
  7. #1297
    solitaire's Avatar
    LT, jonava
    deleted...
  8. #1298
    Jan 2017
    USA ����
    Quote Originally Posted by weza247 View Post
    KAWASAKI KW16 Blade
    kw16 silca same as x103 ilco
    silca card 151
    instacode card 58
    hpc card cmc50/pmc50
    and instacode cannot communicate this info to machine............
    what the ~~~~ is the point of having instacode connectivity if it doesnt work.............................................. ..............................
    if you want to try it you can try to cut it with ssy2
    just make the 7th cut a 1
    and you would have to use 2 as 1 3 as 2 4 as 3 and then if you needed to cut a 4 just make it a 3 and cut it deeper with a file
    but thats why i always have a manual HPC punch with me
    dont need any of this stuff
    just clamp it up and use a micrometer card if you have to but generally theres already a card for it
    btw just open up the custom key tool and make your own card for this key and upload it to the xc-mini in about 5 minutes
    yea i timed it
    it took me 4 minutes
    i made the file for you
    its on my computer you want?
  9. The Following User Says Thank You to sleepyrz For This Useful Post:
    weza247 (18th May, 2019)
  10. #1299
    Mar 2016
    South Africa
    Quote Originally Posted by sleepyrz View Post
    silca card 151
    instacode card 58
    yea i timed it
    thanks i already built it up and loaded it. i find you have to fit key in exacly flat for measure and cutting. mine works ok thanks alot
  11. #1300
    Mar 2016
    South Africa
    silca card 151
    instacode card 58
    yea i timed it
    i did notice the 3 and 4 cut is slightly off but worked my way around it.
  12. #1301
    Jan 2013
    how to cut bmw F10 mechanical key i not find it in condor
  13. #1302
    solitaire's Avatar
    LT, jonava
    Cut by bitting
    h100r
    enter manually
  14. The Following User Says Thank You to solitaire For This Useful Post:
    fytfh (21st May, 2019)
  15. #1303
    PierreTheron's Avatar
    Centurion,South Africa
    I not find any Avanza keys in Condor database
    Is it going to be added one Day ???
    On ignition lock i find cutting code E314A
    I waisted about 5 blanks and still not opening the lock with any off them
    So will have to strip lock further apart
    Ok stripped lock
    Cutting code by bitting is 23 21 23 34 22
    from the levers .
    This looks like toy43 key for corolla but cutting it this way is also no go ????
  16. #1304
    Jan 2017
    USA ����
    do you look the car up or something to cut keys??????
    just a 2 second google search shows me its not even a toyota its a daihatsu ~~~~~
    you dont have a 10 cut lishi?
    also what year is it
    and most toyota has key code on passenger door lock or if absent it is on drivers door lock
    your ignition code i dont think means anything tho
  17. #1305
    Jan 2017
    USA ����
    oh lool i forgot toyota wafers are stamped backwards
    4=1
    3=2
    2=3
    1=4
    try cut to code 62045
    or code 53204
    depends on if you translated wafers or not
    one of those should work
