>>>>>>>>>>>>>>CONDOR KEYCUTTERS <<<<<<<<<<<<< - Page 88
Page 88 of 97 FirstFirst ... 38788384858687888990919293 ... LastLast
Results 1,306 to 1,320 of 1450
  1. #1306
    Dec 2018
    8
    Downloads
    Uploads
    Hello, i had problems to cut a HU43 (picture is Original Key) it can close the door but dont open it and it cant Circle the ignition, too.
    unfortunately i dont have picture from the spare key which doesnt work...
    experience?
  2. #1307
    Mar 2016
    JHB SOUTH-AFRICA
    278
    Downloads
    Uploads
    Default BW9MH BMW BIKE KEY FORMAT CUT
    Hi can XHORSE modify this file format for me please.
    check original cut on top
    and condor mini file i loaded cut bottom key.
    key cuts perfect all measurements is perfect just the way it cuts
    sometimes the key cuts but key falls out of ign.
    bottom key is cut wave style the cutting format is not good. if xhorse can fix this file i will load the key file
  3. The Following User Says Thank You to weza247 For This Useful Post:
    RG550 (13th June, 2019)
  4. #1308
    14
    Downloads
    12
    Uploads
    I got xc-mini plus today, but the display does not turn on.
    Is there power switch other than main power button?
  5. #1309
    Mar 2016
    JHB SOUTH-AFRICA
    278
    Downloads
    Uploads
    can SAMIC help with this
  6. #1310
    HeXeN's Avatar
    Mar 2015
    797
    Downloads
    6
    Uploads
    How to cut Kawasaki KW14 with condor ?
  7. #1311
    HeXeN's Avatar
    Mar 2015
    797
    Downloads
    6
    Uploads
    Volvo HU56R, where is the problem?
  8. #1312
    HeXeN's Avatar
    Mar 2015
    797
    Downloads
    6
    Uploads
    Jaguar HU101. Probe got damaged while trying to decode blade.
  9. #1313
    Jan 2017
    77
    Downloads
    Uploads
    Yes I warned about this somewhere
    You need to scrape key with a file
    It is aluminum and has layer of oxide that is non-conductive
    Scratch key a lot on sides where it touches clamp and on tip of key and where wafers touch then you will get a good read
    I did this on a landrover
    Same thing broke tracer
    Then I figure it out need to scratch key so it will conduct electricity for probe
    The thanks button is over there looks like this --->>>
  10. #1314
    auto techniek's Avatar
    Mar 2017
    337
    Downloads
    7
    Uploads
    Guys
    Hoe often do you calibrate this piece of s**t. Today tried to cut h64 blade. Made 10 blades and only one could close the door but not open.
    Original blade hu64 duplicated on hu64-3
    May be i do something wrong who knows.
  11. #1315
    Apr 2016
    uk
    510
    Downloads
    Uploads
    Quote Originally Posted by auto techniek View Post
    Guys
    I never calibrated it
    I also done one update,1 year ago.
    When I cut hu64 I check machine if decoding ok,when when touching the bites.
    Sometimes does not decode well,you can actually see it during decoding.
    If does not decode well,I decode by eye and than cut.if decode well I just take the bytes and choose hu64-3 on cutting by bites and input the bytes..
    It's a bit tricky but it works!
    Good luck!
  12. The Following User Says Thank You to comizelu For This Useful Post:
    auto techniek (30th June, 2019)
  13. #1316
    Apr 2016
    34
    Downloads
    23
    Uploads
    IMG_20190311_142200.jpg cut the stair on the key
    look at the photo
    Attached Thumbnails Attached Thumbnails
    Click image for larger version.
  14. #1317
    Faraday's Avatar
    May 2012
    The dark side of the moon
    1,702
    Downloads
    38
    Uploads
    Guys
    I did hu64 no problem.
  15. #1318
    Mar 2017
    337
    Downloads
    7
    Uploads
    Quote Originally Posted by Faraday View Post
    How to determine which hu64 to choose?
    I use this. Some times get Suc6 but mostly not. Yesterday cut 10 Keys none of them worked. Only one could close door but not open it.
  16. #1319
    41
    Downloads
    11
    Uploads
    As some users told you, first decode as hu64, see if it's decoding ok, if not, try other options, and always cut as hu64-3. I never had problems.
    Enviado desde mi MI 9 mediante Tapatalk
  17. The Following 2 Users Say Thank You to hipolitogt For This Useful Post:
    auto techniek (30th June, 2019),Weasel3 (30th June, 2019)
  18. #1320
    Junior Member wheepy's Avatar
    Dec 2016
    Switzerland
    22
    Downloads
    Uploads
    Quote Originally Posted by sleepyrz View Post
    yes same way i did it
    cut off head of key
    stick in blade and cut
    duplicate key onto another one with head
    I found another solution for GT15R and other keys not long enough.
    Simply bought a second M1 clamp, and did cut the clamp directly to have more room for such keys
