Page 89 of 127 FirstFirst ... 3979848586878889909192939499 ... LastLast
Results 1,321 to 1,335 of 1900
  1. #1321
    Junior Member wheepy's Avatar
    Dec 2016
    Switzerland
    Quote Originally Posted by auto techniek View Post
    How to determine which hu64 to choose?
    I use this. Some times get Suc6 but mostly not. Yesterday cut 10 Keys none of them worked. Only one could close door but not open it.
    In my case I have noticed this :
    - Older keys = decode HU64
    - Newer keys = decode HU64-2
    Cutting : always HU64-2 (on VVDI BGA keys). If decoding was on older keys, then re-input values manually.
  2. #1322
    Dec 2016
    Switzerland
    Quote Originally Posted by kluczbum View Post
    Attachment 631563 cut the stair on the key
    look at the photo
    Volvo HU56R, where is the problem?
    Attached Thumbnails Attached Thumbnails
    Click image for larger version.
    This looks more like HU43 or SIP16 to me, but in any cases, older version of HU56R in Condor were bad and cut too low.
    Maybe you can try to get latest update, if not done already ?
  3. #1323
    auto techniek's Avatar
    Mar 2017
    Quote Originally Posted by wheepy View Post
    I was told vvdi be keys always use hu64-3.
  4. #1324
    May 2013
    The difference between these are where the first and I guess the last bit begin and end. HU64-3 first starts on 3.80mm, Hu64-2 4.50 and HU64 5.80. Sometimes the shoulder toward the back of the key needs some filing so that the key can go deeper in to the lock or it won't match up with the bitting.
  5. #1325
  6. #1326
    Germany
    I´m proud owner of a condor mini plus now. My first key was opel corsa c, cutted by code from carpass. All went well. Today I tried to cut plastic emergency key passat 3C. First I wanted to decode the original key. I dont know, what is different at this key. At the beginning of decode the machine broke the probe!!! Not at the clamp (M2-C), but at the key. The dimensions of key looks same like metal blade of Golf4/T5 Flip Key Blade. I have a spare probe. Installed, made height calibration and clamp calibration for Clamp M2. But didnt try to decode again and decoded by my eyes and tried to cut direct from bitting code. But it seems, that the material is to soft. The maschine abort with error. Any tips?
    Greets MR...
  7. #1327
    Apr 2016
    uk
    Quote Originally Posted by brobble View Post
    Greets MR...
    Plastic keys.. cut with manual machines!
  8. #1328
    Feb 2014
    Greets MR...
    Have you ever heard of plastic keys which are able to conduct electricity? Me neither!
  9. #1329
    Oct 2016
    Scotland
    Greets MR...
    The tracer probe works by conducting a small current through the probe, key blade and clamp back to the machine.
    i.e. when probe touches the key blade it connects and will stop the probe moving and basically record the position.
    Since plastic key doesn't conduct electricity it won't detect the blade and keep moving until probe break.
    Similar situation when try cut a blade, machine wil not 'SEE' the blank plastic blade and will give error.
    One possible way around this may be to insert the correct type metal blade and press cut... let it detect blade then before it start cutting press pause button and switch metal blade for plastic.
    (NOTE: Never tried this method myself, but have heard others discuss and recommend this method)
  10. #1330
    Jan 2017
    USA ����
    Indeed plastic doesn't conduct electricity
    Machine is only as smart as it's operator
  11. The Following User Says Thank You to sleepyrz For This Useful Post:
    musti418 (4th August, 2019)
  12. #1331
    Germany
    Oh, I didnt know, that the probe works with electric current. Sorry for my stupidity... :-)
    Greets MR...
  13. #1332
    Jan 2018
    CA, USA
    Quote Originally Posted by WRX 14 View Post
    i cut plastic keys using this method, no issues.
  14. #1333
    jodge's Avatar
    Mar 2017
    card 164 blade YM15
    Mercedes blade
    It's cuts the tip of the key like GT15 and bcose the thicker blade and the speed also broke the cutter too around half way
  15. #1334
    Feb 2014
    Not cool. Which speed setting was your machine set to ?
  16. #1335
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by autoTkey View Post
    absolute default settings i never adjust the speed..etc
