Page 9 of 129 FirstFirst ... 45678910111213141959109 ... LastLast
Results 121 to 135 of 1932
  1. #121
    Sep 2015
    Today i cutted a NE72 Key for clio2 but key wont turn after copy with condor.
    I have to repeat with manual key cutter after that its ok somebody else also have troubles with it?
  2. #122
    Jul 2015
    Never had problem with that key. Maybe the decoding wasn't correct.
  3. #123
    rob h's Avatar
    May 2011
    Did you try to put in the code manually?
    Quote Originally Posted by hbt View Post
  4. #124
    Need to Cut a key for MCC Smart For Two (Gen 2) 2007>, VA2MH anyone done one?
  5. #125
    Sep 2015
    No i did copy the key.
    Condor decode the key and cut it but it was not 100% it was like97% good after a lillte mod it was ok
  6. #126
    you have not placed the key 100%.... either whilst decoding or cutting.
    but sometimes edge keys can decode wrong due to the probe being too big to touch right down to the cut ( probably not on ne72 though)
    The cutter can also be worn etc
  7. #127
    Greece
    I have this problem with ne72 but mini have 2 selection for this key. If choose second selection cut a little deeper. This work ok for me all the time. Also if look on instacode is 2 card for ne72. Mini cut ok on this. I have test it with caliper.
  8. #128
    AndyCZ's Avatar
    Jan 2014
    EU
    Megane/Scenic key card not cut correctly. Key cannot go in lock. Fixed extra cut with manual machine.
    If I helped you know what to do..
  9. #129
    Jul 2015
    Quote Originally Posted by AndyCZ View Post
    I have cutted only Laguna II - it was OK. Although it wasn't easy to insert first time.
  10. #130
    CaioW's Avatar
    Oct 2015
    Everywhere
    You need to buy the adaptor, there is 2 types for Megane and Laguna keys.
    cya
  11. #131
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by CaioW View Post
    cya
    which adapter did you mean? Can you send the link?
    There must be extra cut. Check the picture. I'm not talking about cut thickness.
  12. #132
    would help if you posted what machine you have, the bitting, the size of the cutter used.
  13. #133
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by paul_12345 View Post
    condor mini, cutter 2.5mm
  14. #134
    rob h's Avatar
    May 2011
    You can create a new key file and load it in the Condor.
    Use the: Key data customize tool.
    It can help you overcome these problems faster.
  15. The Following 2 Users Say Thank You to rob h For This Useful Post:
    AndyCZ (17th January, 2017), Jobeso66 (16th October, 2017)
  16. #135
    CaioW's Avatar
    Oct 2015
    Everywhere
    http://key-code.com/es/accesorios-de...lt-condor.html
    This ones
  17. The Following User Says Thank You to CaioW For This Useful Post:
    AndyCZ (18th January, 2017)
