Also useless m4 jaw
Doesn't even do a good copy
It is just complete garbage
Add it to the custom key tool so we can make it decent you friggin goofballs
Also useless m4 jaw
So here's the deal with the ym15
in their infinite wisdom the xhorse team decided to set the maximum key blank length in the custom key tool and I believe in the entire machine to 3000 or 30 mm
the problem comes with this key blank being 33 mm and the Condor allows another mm around the tip to pass by as it goes to side B
this is impossible for this machine to do the only way to cut this key is to have your hand ready to pull the blade back so it doesn't hit the tip..............
Xhorse could fix this they choose not to.......
I can't even fix it myself with the custom key tool!!!!!
It only allows max 30mm key blank length in the program
And add to this the birth problem with VA2 emergency blade... Why so hard to fix these ?
maybe we can ask Mr. PremierD to make a sticky-sticky post about the know and never fixed errors. Like in the first post or something. All errors in one place and we don't make useless posts this errors in every few months.
Has anyone cutted a Triumph key with Dolphin machine? I was surprised of not finding Triumph on the database. With a bit of measuring and information from here and there, I think this is the right cutting info:
Has anyone cutted this key already and can offer some help?
SAMDoctor (1st August, 2019)
was having a short chat with samic he wanted to know some common house keys to add to the database
i just said so far
kw1
kw10
sc1
sc4
y1
any others we should add??
also added the problem with ym15 tip
and the old gm 6 cut listed in the machine as GM1 wont do anything at all
Silca UL050 and UL054 here in the UK. Yales are also popular.
TN16X, AGB1, BK15, CS206, CS85
Silca, EU, Croatia
Hi!
I have found a few keys (motorcycles mostly) that need a diferent profile in the key tip, but some of the blanks doesn't have that tip profile. How do you cut these? It would be great if the Dolphin could have a "tip shaping" cut for these blanks.
Letīs say a Yamaha key, Silca YH35H blank. This is a chinese blank:
But the real key has a different tip profile:
Iīve filed these to fit, but would be great if itīs part of the key cutting routine (like the 9th cut on VAG keys).
