Page 91 of 127 FirstFirst ... 41818687888990919293949596101 ... LastLast
Results 1,351 to 1,365 of 1900
  1. #1351
    Apr 2016
    how to normal cut hu101/hu64 with xc002, fastening is problem
  2. #1352
    Jan 2018
    CA, USA
    My xc condor mini 1 is getting very loud when cutting. Like a screeching sound when it cuts the blade. Sometimes it’s doesnt but lot of the times it does. Anything I can do to help? Maybe a maintenance I need to go over? Also this issue is with brand new blades as well. Have it for 1 1/2 year now. Besides that cuts no problems
  3. #1353
    Jul 2018
    CHINA
    Quote Originally Posted by cniksor View Post
    hi , pls add this skype : xxxxxxxxxxxxxxxxx for solve your issue
  4. #1354
    Jun 2014
    How can we cut and decode the newer Toyota key in Mini e b toyota key - Copy.jpg Condor, This ones from a 2013 Toyota Auris. I couldnt find any option in Mini for it.
  5. #1355
    jodge's Avatar
    Mar 2017
    it's VA8
    rob h made a custom key file for it
    https://www.digital-kaos.co.uk/forum...ghlight=toyota
  6. The Following User Says Thank You to jodge For This Useful Post:
    dustin2014 (13th August, 2019)
  7. #1356
    Jun 2014
    Quote Originally Posted by jodge View Post
    it's VA8
    Thanks Rob & Jodge
  8. #1357
    Apr 2016
    condor mini PLUS contains battery inside?
  9. #1358
    Jun 2013
    Please do some work on the HU64 in the APP.
    Decode:
    HU64-1 Get numbers and cut exactly the same blade.
    Result: different than original, but some similarity. Does not work in the lock cylinder.
    Then take a new blade.
    HU64-3 write in the same numbers decoded.
    Result: Looks more like original cut blade, but not 100%. And also work in the lock cylinder as original does.
  10. #1359
    Jul 2018
    CHINA
    Quote Originally Posted by K1nd3r View Post
    no , it no has battery , need to connect with power cable
  11. #1360
    Jul 2018
    CHINA
    Quote Originally Posted by Weasel3 View Post
    Decode:
    for the HU64 , it has 3 types , hu64-1 ,hu64-2, hu64-3 , it is only the tip is different about those 3 types , the angel is not the same , if you can not make sure which if your key ,you can use universal decode to copy one exact the same key ,
  12. The Following User Says Thank You to PerryZhang For This Useful Post:
    Weasel3 (15th August, 2019)
  13. #1361
    Dec 2016
    hi friend where did you buy your xhorse condor mini for europe ? thanx for advice
  14. #1362
    Jun 2013
    Quote Originally Posted by PerryZhang View Post
    I use this pictures as a reference.
    Those two in the middle, I choose as HU64-1.
    I tried to decode Universal on side B on the clamp. It would not sense the key, when I tried. But I can do some more tests in the Universal part, locally. To be prepared.
  15. The Following User Says Thank You to Weasel3 For This Useful Post:
    Buzztek (1st September, 2019)
  16. #1363
    Jan 2018
    CA, USA
    DOLPHIN, when i do all keys lost and use key database, it shows inaccurate key cut. if i use the same key code on my condor mini, it shows correct cut. anyone have this issue as well? i cant trust the dolphin database and i have it all updated.
  17. #1364
    Jun 2013
    Yes there is some work to do here. HU162T also fails.
    But fail less than A9.
    Managed to open with key cut, but not close. The A9 couldn't even do that. The side cuts is the problem, on both machines.
    When attaching the HU162T blade to the Dolph, I used a HU101 as a tool. I cut a bit of the end, where the Roller pin is attached. Removing any sharp edges.
    And it worked quite good as a spacer. To fasten the blade to the clamp. When needed to place the blade in horizontal position.
    Earlier with the HU64 I managed to do different types of blades. One blade style, open the door fine. But not close. The other blade style, do not open. But closes fine.
    But the A9 struggle even more on these.
    Except for the old W203 style, which is good. Just needs to grind off a little bit of metal at the top of the key blade (Key ring side). So the end of the tip, will be touching the small metal measure tool.
    There is about 1mm in difference. And there is the CN factory of the blades, who makes this small error in production. And made me an headache, before I found this easy solution.
    Not talking about the #1358, but another vehicle.
  18. #1365
    Jul 2016
    Quote Originally Posted by sleepyrz View Post
    was having a short chat with samic he wanted to know some common house keys to add to the database
    i just said so far
    kw1
    kw10
    sc1
    sc4
    y1
    any others we should add??
    also added the problem with ym15 tip
    and the old gm 6 cut listed in the machine as GM1 wont do anything at all
    Also
    Best Commercial Key 6 and 7 Cut
    HU100 10 Cut
