Page 96 of 127 FirstFirst ... 4686919293949596979899100101106 ... LastLast
Results 1,426 to 1,440 of 1900
  1. #1426
    Mar 2016
    South Africa
    I asked to adjust the bmw motorcycle cut from Asian cut to European cut months ago also no responce
  2. #1427
    Jan 2017
    USA ����
    Yea they keep updating the dolphin as it is app based
    I dont think they can fix the mini or mini plus
    If they could it would have been done YEARS AGO
  3. #1428
    Jul 2016
    Wish the wood at least update the software. So we can try adding out own single side keys.
  4. #1429
    Jan 2017
    USA ����
    been asking for this as well for as long as it has been out
    i dont think they still have engineer for this part
  5. #1430
    Jan 2018
    CA, USA
    DOLPHIN ISSUES
    database still giving incorrect key code for bmw . if i enter same key code on condor mini or instalive, i get correct key cut, if i enter on dolphin i get incorrect, i cannot trust using data base for dolphin
  6. #1431
    Jul 2018
    CHINA
    Quote Originally Posted by cniksor View Post
    DOLPHIN ISSUES
    the database between those 2 machines are the same , what is the database version of dolphin ?
  7. #1432
    Jan 2017
    USA ����
    Quote Originally Posted by PerryZhang View Post
    See told you
    Hes completely ignoring anything with regular xc-mini
    And only responds to dolphin
  8. #1433
    Jun 2013
    Dolph:
    HU64-3 decode
    and
    cut HU64-3.
    Result: Success.
    Things are getting better.
  9. #1434
    Jan 2018
    CA, USA
    Dolphin is up to date. It’s never given the correct key cut code. I have to use istalive or condor. Will film video on the issue
  10. #1435
    auto techniek's Avatar
    Mar 2017
    Can someone decode by eye?
    Is it 8-9 or 10 cut?
  11. #1436
    Jul 2018
    CHINA
    which one you can not , can you add this skype : xxxxxxxxxxxxxxx . and send the video .
    Last edited by gmb45; 29th October, 2019 at 08:42 AM. Reason: no skype in posts !!!
  12. #1437
    rob h's Avatar
    May 2011
    Jaguar Tibbe 8 cut key.
    I can not cut the nr.2 angle.
    There are 4 positions on the clamp, M3.
    Nr2 angle should be 2000 value, clamp 2 pos, is 1100, and 3 2450.
    Both are way off.
    How does one solve this?
    Cut using Ford angle 2 and file down? There should be a better way. Jaguar tibbe.jpg
  13. #1438
    Greece
    on jaguar n2 is like n3 on ford
  14. The Following User Says Thank You to kleidaras For This Useful Post:
    rob h (7th November, 2019)
  15. #1439
    sdnatlst's Avatar
    Aug 2011
    England
    1 month old dolphin and cutter is sized in socket
    Any ideas before I return To my supplier?
    Tools owned -
  16. #1440
    rob h's Avatar
    May 2011
    You mean, it is stuck?
    We can see, that it is broken.
    What is the problem,
