Here is video showing incorrect database for DOLPHIN. this happen every time i try using database. dolphin is fully updated firmware and database and every time same issue here is a sample of same code on dolphin and condor mini...and original car key, which shows mini is correct code.
dolphin
https://vimeo.com/372280385
mini
photo of correct/original key
UPDATE:
i finally figured out the issue. xhorse support helped
now the issue. on condor mini i can input ha00038828 and i get correct code. i always enter full code on condor mini and never any issues.
BUT on dolphin you dont enter full code, only 4 digits of the sample that is highlighted. in this case 3882, which then gave me the correct cut code.
bit strange that it works on condor mini this way but not on dolphin, either way, in case anyone else is having issues, hope this post help. and thank you xhorse for support once i provided videos.
two pairs of pliers and some heat on outer collar
sdnatlst (12th November, 2019)
Can all the keys cut by this machine and saved on the internal memory be saved on and external?
Sent from my SM-G930F using Tapatalk
internal memory , yes , it can save to internal memory , but can not save on external memory . you can check the memory in history , it will show all keys you cut before,
trinicolin (13th November, 2019)
you can always set up monitoring in the store, proposed vhs systems,
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
Hello to all.
does someone know how to cut va6 keys ? Like Renault Clio3 with condor mini.
i have never success to cut these keys even in akl nor for duplication..
thxw
which key blade code this is? Renault laguna 2
try va2eh2 , this blade ,
auto techniek (19th November, 2019)
I have also problems with va2 and hu56, not working correkt.
