Page 114 of 127 FirstFirst ... 1464104109110111112113114115116117118119124 ... LastLast
Results 1,696 to 1,710 of 1900
  1. #1696
    Quote Originally Posted by PerryZhang View Post
    i tried hu83 blade with xp005 machine firmware version 1.4.9 , use 1.5mm cutter, cut 2 type , hu83 , hu83 extra, both fine
    what menu did you use ?
    please see below a video i made of the issue i have with HU83 cutting ( it's the same using 1.5mm and 2mm cutter), you can also see i am using fw 1.4.9
    https://streamable.com/xgyx43
    i would appreciate it if you could also post a similar video showing the HU83 cut is working fine for you,
    EDIT: issue resolved after full recalibration of machine.
  2. #1697
    P&D's Avatar
    I would recalibrate the whole setup as i installed the update after cutting one key then fully recalibrate machine after the update all good
    Height level
    clamp calibration
    cutting calibration
    not the best video......https://streamable.com/uh7h50
    the only difference I can see you have ticked low speed high accuracy cutting......untick it
  3. The Following User Says Thank You to P&D For This Useful Post:
    u.s (5th January, 2021)
  4. #1698
    P&D thanks for taking the time to test this.
    Happy to report that a full recalibration ( Height level, cutting calibration, clamp calibration) managed to sort this issue out.
    Pic below, blade on left after calibration, blade on right before calibration.
  5. The Following User Says Thank You to u.s For This Useful Post:
    P&D (5th January, 2021)
  6. #1699
    Jul 2018
    CHINA
    for dolphin machine, you can try to calibration it if you find some key cut not so precise ,
  7. #1700
    P&D's Avatar
    There's an update 1.50 installed it still no fix for the VA2
  8. #1701
    Quote Originally Posted by P&D View Post
    what is the issue with va2 mate?
  9. #1702
    P&D's Avatar
    Won't decode them and when you cut them they get stuck in the lock
    anyone got an alternative in the app for the SZ17 profile
  10. #1703
    Dec 2016
    Today , just bad decode in 30% of case , never more get stuck in the lock .
  11. #1704
    P&D's Avatar
    I did decode one with the Universal key duplication
    it came out perfect but the car had gone so i could not check it
    but the cuts where correct after checking them with a venier
  12. The Following User Says Thank You to P&D For This Useful Post:
    TERMINATOR1000 (19th January, 2021)
  13. #1705
    P&D's Avatar
    UPDATE seems to be fixed ? 1.51fw......sod's law no cars to try it on
    read and decoded and cut
    VA2 & VA6 at last
  14. The Following 3 Users Say Thank You to P&D For This Useful Post:
    mikajna (28th February, 2021), rob h (26th January, 2021), u.s (26th January, 2021)
  15. #1706
    Apr 2016
    condor mini plus also so problematic as dolphin?
  16. #1707
    Jun 2019
    I am now having issues with Dolphin cutting HON77 keys. Have three customers waiting These were working fine earlier this month.
    There is some material not removed from the start of the track. Anyone having the same issue?
  17. #1708
    Feb 2014
    Did you complain to support?
    In the Xhorse APP?
  18. #1709
    Jun 2019
    Yeah, yesterday, but I am in a different timezone and didnīt got a reply until today. Talking about the usual stuff, updating the firmware (already 1.5.1), doing universal key duplication (I am cutting from code, cannot do it) and so.
    I think it might be related to the latest V73 database, because it was working earlier this month. Do you know any easy way to roll the DB back?
  19. #1710
    Jul 2013
    Can somebody confirm that is corect code, decode by eye. It is va6 from ds3
    657668
