Page 14 of 127 FirstFirst ... 49101112131415161718192464114 ... LastLast
Results 196 to 210 of 1900
  1. #196
    Jan 2017
    USA ����
    I think my tracer when it comes down to touch the top of the calibration block isn't detecting correctly
    It sort of hits on it hard
    And on his video it just gently touch the top
    Mine makes a solid thunk noise
  2. #197
    rob h's Avatar
    May 2011
    It might appear that way, butt if you run the same Software version, it should be the same.
    And the moving speed, in the settings: if you seth it to lowest, is there a slower calibration proces?
    Conductivity tells the needle that it made contact, so that is a all or nothing thing.
    Did you lower the needle, and cutter and 1mm, did this have any effect!
    Quote Originally Posted by sleepyrz View Post
  3. #198
    rob h's Avatar
    May 2011
    Many have tried to reach Samic, true This forum, P.Ms, Skype etc.
    There does not seem to be any reasanable support.
    If there whas no D.K., we would not have any support at all!
    More then a month ago my Condor master failed me.
    The only bit off support, whas update software, which i allready used.
    Then i asked them, if i could buy a new touchscreen. And i have heard nothing since.
    So i have to say, Xhorse needs to do something.
    If Samic or Condorsupport is not capable ennough to advice on repairs, then attleast they should us sell parts.
    Providing us with parts catalogs, would be a good start!
  4. The Following User Says Thank You to rob h For This Useful Post:
    kleidaras (25th February, 2017)
  5. #199
    Feb 2014
    Usually, when I have been in such trouble(something burnet or failed) I send them video of the problem, then send them the failed part and they return me a replacement.
    I suggest you to try this. Because their engineers, I mean the people who actually can support you, usually don't speak english and a video helps a lot. If you just send them questions in words it is harder for them to understand and probably it is hard for Samic to explain to them too(if he is still in the company). So they tend to postpone their replies for indefinite time...
  6. The Following 3 Users Say Thank You to autoTkey For This Useful Post:
    amigokola (10th March, 2017), AndyCZ (25th February, 2017), rob h (25th February, 2017)
  7. #200
    Moderator
    PremierD's Avatar
    Jun 2009
    He is still in the company ... currently doing remote research .....
  8. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    AndyCZ (25th February, 2017), autoTkey (25th February, 2017), rob h (25th February, 2017)
  9. #201
    rob h's Avatar
    May 2011
    I will send them all the pictures and vids that i have made.
    Getting my med17-edc17 vvdi2 tool activated would be about time. That request whent out in december 2016.
    About Samic: He is not remotely researching my Condor problem is he!?
  10. The Following User Says Thank You to rob h For This Useful Post:
    clintezra (15th June, 2017)
  11. #202
    Moderator
    PremierD's Avatar
    Jun 2009
    Jan 2017
    USA ����
    Does not have suz18 in menu.......
    Any idea how I can cut this key????
    Suz18/x241
  13. #204
    rob h's Avatar
    May 2011
    Choose YH35
    Suz18/x241
  14. The Following User Says Thank You to rob h For This Useful Post:
    sleepyrz (4th March, 2017)
  15. #205
    Jan 2017
    USA ����
    Thank you sir
  16. #206
    dave11674's Avatar
    Florida, UK
    Hi guys
    im thinking of buying a condor mini
    any advice
    and does it come with all adapters ?
    ill be doing a lot of mercedes key cutting mainly
    thanks for advice here
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  17. #207
    Feb 2014
    Only Ford clamp need to be ordered separately.
    My advice is to buy it together with VVDI BGA tool.
  18. The Following User Says Thank You to autoTkey For This Useful Post:
    dave11674 (11th March, 2017)
  19. #208
    lpf01's Avatar
    Oct 2013
    It comes without ford/sx9 adapter, you need to buy it separately.
    I made a lot of Benz with it, YM15 and HU64 without problem on tracing and cutting too.
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  20. The Following 2 Users Say Thank You to lpf01 For This Useful Post:
    dave11674 (11th March, 2017), daxxer (11th March, 2017)
  21. #209
    dave11674's Avatar
    Florida, UK
    I dont need vvdi bga tool
    i have avdi mercedes full
    thanks for the input guys
    appreciated
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  22. #210
    Jan 2017
    USA ����
    for the chrysler key that it would not decode properly i just angle the key a tiny bit so the left side of the key is slightly higher.............
