Hi guys, what's the latest update for Condor XC mini?
6.4.5 te latest version
Autronico2 (14th October, 2021)
very good for now
Autronico2 (16th October, 2021)
does anyone use Xhorse Panda ?
Cut Lexus TOY48, key blade too short, can not reach 2 line positon.
Visit my homepage
If my reply's useful, give me 1 thanks + reputation
Almost none use the Panda outside China, and the countries in that area.
It has not been marketed much, other places.
Dolphin is the one, which is possible to get all other areas.
And the big brother with touch screen. Condor XC-mini.
A manual machine, would probably solve your problem. In this case.
Take the pin out of the holder.
Xhorse Panda is not sold in EU or US. Only Condor and Dolphin. Now they have Dolphin II and Condor II
https://www.vvdishop.com/wholesale/x...g-machine.html
Screenshot_20211031-154822.jpgThey need to fix the photo to keycode in the app.
It will not allow you to slide the picture up and down, to fit the raster.
If you did not have the correct picture size(sometimes just the blade without grip),
then there is no way to slide it in place.
you should be able to slide your picture beyond the edges.
i can slide it only a few millimeters. I tried cutting the picture, and adjusting it in size. But i can not ad to the outer side, so to be able to slide it down more.
I tried all, in reason, to use the app as intended.
zooming will not help, because off the key width itself. It will not work..
Lucky for me, i dont need this often.
Would be better if they fix this.
Hi guys. Have a problem with cutting this key.
Is any way to cut it on condor mini?
Sent from my SM-N960U using Tapatalk
