Page 111 of 127 FirstFirst ... 1161101106107108109110111112113114115116121 ... LastLast
Results 1,651 to 1,665 of 1900
  1. #1651
    Jul 2015
    KM03 v6.1.5: can't detect SX9 - solution: downgrading
    v6.1.6: VA2 cannot be inserted into the lock - solution: downgrading
    HU56: cutting in the adapter D the key doesn't turn in the lock - solution downgrading and using adapter C
    HU56: cannot be detected in the adapter A
    I want to go back to v6.1.0 but it doesn't detect anything in the adapter M1. The machine has been ruined since v6.1.1. Seriously, wtf?
  2. The Following 2 Users Say Thank You to gokart For This Useful Post:
    fred77 (9th September, 2020), jodge (11th September, 2020)
  3. #1652
    Mar 2017
    Quote Originally Posted by rob h View Post
    The conductivity, of the key to probe is very important.
    If the probe detects key, and warns about blade width.
    Bends or even snaps.
    This all preventable, by scraping the key edge, with something like a file, knife, etc.
    Even a blade, that works one sided better, can be caused by bad conductivity.
    The sx9, and some other Keys that Comes with a yellow collor coating, must be scraped.
    A full charges battery, or charger attached, can improve the conductivity probing. Instead of blaming software.
    Be aware off this.
    Load up, a good picture of the bad cut key,
    Measure it with caliper, confirm manualy the decoding,
    To pinpoint the issues.
    Also, the smal screw, needs to be used,
    Not very tight, but pressing down, to prevent blade from turning when you clamp IT.
    That could make a blade, smaller in width,
    Depending, it being a right OR left blade.
    This might differ sligtly.
    Attachment 736312
    I see you replied to my post. What you are talking about does not relate to me as the cutter was perfect with 603. Some test I did not even move the key or clamp and just downgraded firmware and it worked perfect.
  4. #1653
    Feb 2018
    Hello ... have had my condor mini for over 2 years now and I can not cut toyota L44 key with it, I have to use another cutter ... am I missing something ?
    Sent from my SM-N975U1 using Tapatalk
  5. #1654
    Mar 2017
    616, 615, 610... All give me no key detected error for TOY40 4-4. Im using the spacer sold by xhorse. Have cut over 50 of these keys with the spacer with 603 and had zero issues.
    I reported it to the tech support via the xhorse app. They claim Im putting it wrong on the clamp. ???
    I report it again and this time they say the solution is to lift it up more. Im already using spacer. Any more and key will fall off. ???
    I did the following test. I put the key in the clamp with the spacer and got the no key detected error with all the firmwares I listed above. I even sent them a video. I did not touch key or moved clamp and downgraded to 603 and try cutting it. What do you know...It worked perfect. So how did I put key "wrong" like they say if it cuts on 603???
  6. #1655
    Mar 2017
    Quote Originally Posted by gokart View Post
    Hu56 on D clamp works great for me. Putting it on C clamp does not hold blank correctly as lip on left side gets in the way.
  7. #1656
    auto techniek's Avatar
    Mar 2017
    Guys
    Any one has problems cutting side of HU162t?
    I ve xc mini and since update it does cut it wrong. with the app it does not work.
    Used 1,5 mm cutter and 2 mm . same result
    app not working movie: https://youtu.be/RAViy_Eidr0
    Cutting with the machine software get this cut.
  8. The Following User Says Thank You to auto techniek For This Useful Post:
    fred77 (17th September, 2020)
  9. #1657
    Mar 2017
    For guys with same problem
    Downgrade to version 6.1.0 and everything works wel. It is a bug in the software. Helpdesk is working on it
  10. The Following User Says Thank You to auto techniek For This Useful Post:
  11. #1658
    fred77's Avatar
    Jun 2019
    Terrible wonder if they will ever get right. One thing is excellent is the feedback from you guys
    heard issues with likes of ninja key cutter so sometimes money doesn't always solve issues
    Solidarity with Ukraine
  12. #1659
    Jul 2015
    Quote Originally Posted by ps80l View Post
    Despite the fact that the C clamp doesn't hold the HU56 correctly, it works.
  13. #1660
    Nov 2013
    I've decoded and cut first key (Hu92) on my brand new Condor Dolphin today. Success. Impressed. Very nice. Advice for first timers. Watch some calibrating videos. Change axis speed and moving speed speed from High to Medium. Keep your hands very clean, wipe all clamps and probe, clean key very well (leave no dirt at all!) when decoding. This will prevent you from breaking the probe.
    I also would like to see all current bugs log (confirmed by more than one person), with update when particular bug is fixed. So anyone would know which keys better not to cut at this moment with this machine. It's impossible to read 111 pages for that, it must be in the FIRST post, visible right away and being updated. Should I start new thread for that?
    Xhorse Dolphin XP-005, app. version 1.9.9, firmware version 1.4.4
  14. #1661
    Mar 2017
    618 fixed my TOY40 4-4 issues.
  15. The Following 2 Users Say Thank You to ps80l For This Useful Post:
    rm23 (23rd September, 2020), sleepyrz (9th October, 2020)
  16. #1662
    rob h's Avatar
    May 2011
    I have had a problem with a va2eh2.
    The dolphin milled outside the key surface.
    va2eh2 with cuts 428426, fail to cut proper.
    So i ended up cutting a va2eh2-6-1 421423.
    Hope that this will be fixed soon.
  17. #1663
    fred77's Avatar
    Jun 2019
    bloke who wrote the software should be shot
    obviously drunk at the time
  18. The Following 2 Users Say Thank You to fred77 For This Useful Post:
    rob h (11th October, 2020), TERMINATOR1000 (11th October, 2020)
  19. #1664
    Feb 2014
    They have promised to fix it:
    Watch out for a newer version of their Android app.
  20. The Following 3 Users Say Thank You to autoTkey For This Useful Post:
    immoneard (25th March, 2021), rob h (12th October, 2020), TERMINATOR1000 (12th October, 2020)
  21. #1665
    tagirdn's Avatar
    Aug 2020
    UK Leicester
    While they are fixing it, for example , I threw my card under va6. The truth is not very convenient, it was made in a hurry, but it will go to the correction. Although it is still a question of when it will be. ?
