Contact support.
This is not, how this machine usually works.
No problems with battery, it hold the voltage usually quite good.
But better when it was new.
I hope there is a battery swap program in the future. (If the machine is still supported )
By the way, congratulations all members with the Brexit, I have waited many years for this.
The Champagne bottle is bought in and opened, just for UK and this event.
Full support for Great Britannia, and the new path of the future.
Its a good backup number two.
It saved me today. When number one went down. During a battery drain.
Of a big huge 12V battery AGM, which I forgot remove the clamp.
Which I usually do after a cut.
Cut 101de,64de and 92coAKL as a backup this afternoon.
And made job completed.
Edit:
But number 1 which have very few updates. And 2 which have a lot of updates, failed on FEM key.
Now I understand why I never could do the AKL, after reading the lock. The cuts are to wide on both machines.
I need to update to the latest firmware on the Dolp. Maybe number 2 is getting better.
Had to use manual machine.
Did the job perfectly.
crankycarl (1st February, 2020)
Anyone able to confirm the code of this HU64 by eye? I'm not with the car just now, and i've never had great luck with the XC mini decoding the key, so trying to plan ahead to minimise any problems. I think it may be 2424355312, but wanted to check before i cut it.
Also, does anyone have any yips about using the XC mini to properly decode and cut HU64 blades. Surely i must just be doing something silly that it's not working correctly.
Thanks in advance
Disregard. Cuts correct
WRX 14 (3rd February, 2020)
Dolph
Decode key.
Push button OK decoding.
And accidently at the same time hit the numbers of bitting.
So I change the number, without knowing it.
Cut key. And of course its wrong.
Scratch my head a little bit, bittings by eyes.
Cut OK!
Change blade to new style. To make a new cut.
And I do the same trick again, when touching screen to say OK.
Never done it before.
The OK button should not be in the same area as the bitting numbers.
But I guess this is something to do with the various of screens and sizes.
Maybe not a problem for other users.
But if it is possible.
It would be nice to move the OK button after decoded right.
So it wouldn't happen again.
After last update Honda cutting key fail, the key neck is not cut,(i think axis X - Z are inverter in this area) then the key not go to finish of the lock cylinder. XC-Mini Km03 Ver. 6.0.6
Anyone can share some feedback about CGDI Godzilla? Specs are promising.
After my earlier post re problems with my Dolphin out of the box, I returned it to my UK supplier who couldn't fix it, they have swopped it for a new one which now works perfect.
Weasel3 (12th February, 2020)
