Page 127 of 127 FirstFirst ... 2777117122123124125126127
Results 1,891 to 1,900 of 1900
  1. #1891
    Mar 2019
    Scandinavia
    Question Xhorse Dolphin XP005L failure
    Does anyone have problem with Xhorse Dolphin 2 XP005L and broken probe? I tried to use universal key cut for Mitsubishi key Anna it broke two probe when it should cut the key blade... there's also a big problem to decode Mercedes keys... It's not possible to get in touch with the support...
    learning by doing, learning by experience... please thx is I helped you
  2. #1892
    Feb 2014
    What support do you expect to work on Sunday?
    They will reply, they are always helpful but you must be kind.
    Probably problem with the negative on the machine.
    These cables break easy.
  3. #1893
    Mar 2016
    South Africa
    Hi Condor engineer could you please change the cutting format for bmw motorcycle
    Left is codor cut right is ori blade
  4. #1894
    P&D's Avatar
    May 2010
    Default BM9TE
    Its cut correct 1311 - 1232 you don't say what machine you cut it on ?
    I use the Dolphin & the Condor Plus 2 and they both cut the key same as your cut
    but they both work perfect
    Using the setting below with 1.77 firmware
  5. #1895
    Mar 2016
    South Africa
    I'm using the condor mini the first ones out.
    It does cut the key but on some ignition,s the key falls out the barrel.
    Am I perhaps using wrong software on this tool
  6. #1896
    rob h's Avatar
    May 2011
    Your cutter diameter, is set wrong.
    That is why, it did cut to much.
    Your code.
    1331
    2321
    if i am correct.
    It does look different then the ori key.
    The Condor, did created a smoother key. That is a good thing.
    Use a 1,5mm, sometimes 2.0, never a bigger diameter. And set the diameter correct.
    Slowest moving speed. And cutter revs, high.
  7. #1897
    Mar 2016
    South Africa
    My issue is not the cut..
    The cut works 100%
    It's the cutting format that is incorrect because I've cut alot of these keys and some cuts depends on ignition cut it will cut the key correct but because of the cutting format the key slips out the ignition on the on position.
    I have to put the key in my friends machine then it cuts the correct format.
  8. #1898
    Mar 2016
    South Africa
    I tried the c600 Sport seems abit better
  9. #1899
    Mar 2016
    South Africa
    Quote Originally Posted by P&D View Post
    I tried this c600 sport the cut seems much better now
    Thank you
  10. #1900
    rob h's Avatar
    May 2011
    I missread, yes, a key should stay in place.
    The picture you posted, it does surely look about 0,5mm or so, to deep.
    In some cases, i simply copy the key.
    The tracing is very accured. With exception of the keys tip. The lead in, is not always ok.
    This way, you will have the steeper slopes.
    Xhorse support, they do read these topics.
    Perhaps next update, they fix this BMW key.
