The fap and egr is out and only have the dtc 48a7?
I read Full with KEss V2 , someone make a file 2 weeks ago, Today car return limp mode and have dtc 48a7 Code, Unknown Faut,
ideally small power, and proper correct DPF off,
Please,
whats 48a7 fault ? we assume either EGR or DPF
Thanks in advance, Mates
HW: 0281012722
SW: 1037389899
VIN nr.: XXXXXXXXXXXXXXXXXX
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.: 07808470
Installation:
Yes. was ok 2 weels. then limp and this DTC . u know what DTC is ?
Is posible that problem energy or inyector.
This error code is BMW, which is the generic code?
I can delete this error but test which is the generic code error.
Pass on PM
First off all, this is not a Full read, just OBD... but this is not important.
Second - this file is original. http://www.digital-kaos.co.uk/forums...722-1037389899
Regards!
Here you go... DPF off by single switch... if you have some error codes, just post them here.
BTW... 48A7 is a CAN comunication error, i've delete it.
lupus80 (6th September, 2016)
I have no idea... scan the MINI with INPA...
And look... i gave you DPF off file. It is same PSA group...
Resolved other MEANS,
Cheers
Did not understand you very well.
Please explain what the problem was and how you solve it.
morgano (30th July, 2016)
