Results 1 to 5 of 5
Thread: Bp car 2003 (F)
Hybrid View
    Dec 2009
    Serbia
    Default Bp car 2003 (F)
    Hi !
    Can somebody help with this radio ?
    Blaupunkt Car 2003 (F) , from Opel Corsa
    7 649 200 321
    Ser: GM020328221597 , on label
    Code from calc is --2526-- , but not correct
    Can`t read MCU (MC68HC05B6), maybe any hint, try to cut some wires ?
    Here is 24C01, can I try to read this, maybe help ?
    Thanx for any tip,
    Peter
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by baper View Post
    Hi !
    7 649 200 321
    Thanx for any tip,
    Peter
    opel car 2003 code 2526
  3. The Following User Says Thank You to Decode Ghost For This Useful Post:
    baper (30th July, 2016)
    Dec 2009
    Serbia
    Hi !
    Yes, from calc, but code is not correct,
    after code enter radio go to safe 9, safe 8 , ...
    If leave radio on, ignition on , radio retun to safe 10, I can enter code again.
    Any hint to read MCU ?
    Regards,
    Peter
    Raimax's Avatar
    Nov 2013
    LT
    Radio not should return to its original state safe 10. Entering the code necessary to turn the ignition key.
    For reading Motorola need to cut one wire. Upload photo bottom side here
  6. The Following 4 Users Say Thank You to Raimax For This Useful Post:
    baper (31st July, 2016), masterskay62 (30th July, 2016), safeirakli (30th July, 2016), shooting (30th July, 2016)
  7. #5
    Dec 2009
    Serbia
    Hi !
    Problem solved, in first time I cut on bottom side wire to pin 22, but nothing.
    Next cut wire to pin 50, 52, take old PC 100Mhz and then communication established with motorola MCU
    Eeprom content is erased, only on 2 adress is something, others #FF, maybe MCU was secured.
    Write another dump, and all OK, radio working
    All done with polish Motorola interface, old DOS software or Motorola cracker xx, both soft read, write ok)
    This radio is very similar to BP Car300, where I cut only wire to pin 22, and make conn with MCU.
    Thanx to all for help, problem solved
    Regards,
    Peter
