Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
Hybrid View
    Nov 2014
    Newcastle UK
    Default Injector Coding 1.9DCI 120
    hi there
    was wondering if someone could help me i am having a similar issue i have a 2004 1.9 dci megane 120 and i had a guy out to flash the ecu with tune now upon doing this my codes have now changed to 6 A ie: AAAAAA
    The car starts and idles fine but revs are limited to 1500 RPM as tho the car is in limp home mode as i believe this is due to the injectors having no / incorrect codes.
    Am i right in thinking the codes on top of the injectors on the BOSCH Rail are 6 Digit ? IE: Cylinder 1 = 7RHR4F etc
    would it be possible for someone to help me and give me some clues how to go about recoding my injectors to my car ? i will be buying a clip this week if i know how to reprog them
    thanks in advance
    Chris.
    Sep 2009
    near Strzyzow
    If you used Galletto, use it again.
    Read Injector codes, save file. Then edit previously saved file and write Injector Codes.
    Then write modified file with galletto.
    You should read manual.
    Nov 2014
    Newcastle UK
    thank you for the reply
    The guy flashed it via OBD with what i think was AutoCOM / Delphi
    he then tried recoding injectors but it didnt work so he left saying he was coming back but is now making excuses.
    The only tools i have on hand my self are the galletto 1260 and a KWP 2000Plus
    would any of those work ? and would i need to shell out and buy a can CLIP ?
    thanks again
    Chris.
    Mar 2010
    You can only use genuine codes, so they have to be correct or they wont program even with clip.
    Nov 2014
    Newcastle UK
    thank you
    by genuine codes do you mean the codes upon the heads of the injectors ?
    4 of them stand out like: 7RHR4F - BTHUE6 - 8R1BR1 or the 1 could be an I and AAHWB0
    or are the codes the small numbers below ?
    thanks again
    Chris.
    Jun 2012
    Typical Renault / Nissan Scenario, Guy you used was a noob / Amateur, I assume cheapest tuner around town
    Fact is you lost inj Nozzle codes, he didnt back up and now you need to re write codes, as sure as hell if he had backed up you wouldnt be posting,
    its not the end of the world and most decent tools will re write inj back,
    if he used Kess or Fgtech , should have used the inj read function, Massive FAIL,
    if he had delphi / Autocom can use to rewrite, if not Clip will sort,
    your codes sound ok that you read, just get cylinder 1-4 correct way, and programme your read codes,
    Regards
  7. The Following User Says Thank You to pulsar2000 For This Useful Post:
    chrisl87 (31st July, 2016)
  8. #7
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    coding should be ok with delphi l know this is 15 but the same and number 1 is gearbox end https://www.youtube.com/watch?v=JLMs8T8A5Pc
  9. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    chrisl87 (1st August, 2016)
  10. #8
    Nov 2014
    Newcastle UK
    Hi Pulsar
    He came highly recommended and had done good maps on friends cars so i thought why not
    The injectors in my car have previously been marked to each cylinder ie: 1 2 3 4
    Cylinder 1: 7RHR4F
    Cylinder 2: BTHUE6
    Cylinder 3:
    8R1BR1 looks like a one but some say its an I
    Cylinder 4:
    AAHWB0
    Do the above codes sound correct and what i would need to enter ?
    He used PCW or Precision code works CMDFlash BDM for the ECU Reading and then tried AutoCom / Delphi to reenter the injector codes but was having none of it
    If i purchased the CAN Clip would that allow me to enter the codes ok ? as the injectors have them 6 digits them string of numbers like a serial below
    have been like this since last wednesday
    thanks again
    Chris.
  11. #9
    Jun 2012
    Quote Originally Posted by chrisl87 View Post
    Hi Pulsar
    Cylinder 1: 7RHR4F
    Cylinder 2: BTHUE6
    Cylinder 3:
    Cylinder 4:
    AAHWB0
    thanks again
    Chris.
    I would say good to go,,,,
    it normally says dgits it uses, ie 12345679 abcdef etc,, so shouldnt be a issue, if it s not I then try 1, either way easy fix, suprised a recommended guy had a reanult Job bite him in the ass, Common knowledge Renault / Nissan for losing inj codes with certain tools, no matter what screen tells you, ie Inj codes supported ,,, blah blah B,s B,s Lol
  12. The Following User Says Thank You to pulsar2000 For This Useful Post:
  13. #10
    Nov 2014
    Newcastle UK
    thanks again pulsar
    ive just been having a conversation with another tuner who says if its a BOSCH rail and ECU injectors dont need coded but from what ive read they appear to need codes to remove the limp mode / limited revs he says only the siemens and delphi require codes :s what would your view be ?
  14. #11
    Nov 2014
    Newcastle UK
    just another update i got the rail name wrong
    the ECU is an EDC16 and the fuel rail is a BOSCH rail
    just to also confirm if this is the correct order for the injectors
    1 is marked timing belt side then 2 then 3 then 4 is gearbox side as they have tipex on the sides from 1 to 4 ?
  15. #12
    Mar 2008
    birmingham
    4321 1 is gearbox end
  16. The Following 2 Users Say Thank You to smirnoff_rules For This Useful Post:
    bobolin4o (5th August, 2016), chrisl87 (1st August, 2016)
  17. #13
    Nov 2014
    Newcastle UK
    ah brilliant thanks
    so the codes should go as followed
    Cylinder 1 = AAHWB0
    Cylinder 2 = 8R1B81
    Cylinder 3 = BTHUE6
    Cylinder 4 = 7RHR4F
    and not the way i had them ?
    Thanks again.
  18. #14
    Mar 2008
    birmingham
    yea what ever is written on injector 1 (flywheel side) write that in box cylinder 1 in what ever program you use and so on
  19. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  20. #15
    Nov 2014
    Newcastle UK
    thank you very much i should have my Clip tool tomorrow and will give it a go
    the guy tried coding them the way i originally outlined them hopefully should all work out fine im hoping
