Hello, i am in need of the passwords for ver. 7.6 PCID: 73A73152 if any one has them it would be greatly appreciated thanks !
colh (4th August, 2016)
TRY THESE
BASIC 000A0F5127901325Y4
LITE 001AC75E22402955YW
PRO 00205A0F60B62FD5YW
RSGR 003F37769FFAD6A5YW
ODBRSGR 005CE496A7DF6DF5Y4
ODB 006F52740F218A05Y4
RSGR PLUS 00764D86F39556525Y4
PRO PLUS 0087652402F121B5Y4
ECM PW REM WSS3A0BF6630C375Y4
OEM ECM PW REM ZSSEC078780FEC95Y4
FLEET CAL COUNTS FSSD88EA913E8485Y4
LUIS LUQUEZ (2nd August, 2016)
Hello Friend
The key worked all right.
The only thing when I finished installing INSITE v7.6 CUMMINS in the calibration section gives me a warning
" The INCAL Disc 2 (AUGUST 2015) has expired , they can not take further action on this medium"
I appreciate the help you can give me to solve the problem of calibration
Hi Luis
All incal discs expire is a big problem and since the latest have come out they will only work with insite 8 but i cannot make keys for Insite 8.You can run old discs if you set computer date back to the time of the incal disc that you have but then you have to unlock insite because it does not like time changes.There is a key maker to do this called cummins insite date unlock so if you do reset time you will need it or someone to make the keys for you.Hope this is helpfull to you.
I have another computer with the same software v7.6 Cummins Insite few days ago I left a notice to conduct an update inadvertent error and I said yes , and from there upgrade to v8.2 , and I ask for a new password please if I can help
PCID : 0CE01777
"Run As Date" of this application If in the past time is very popular to GAMERS, it is an ancient but very powerful application to restore the programs that has been expired.
It turned out that until now the application is very extensive functions without exception for software / engineering programs such as Cummins Insite.
colh (2nd August, 2016), LUIS LUQUEZ (2nd August, 2016), MobileTechGuy (18th December, 2018), toshor (17th May, 2017)
Thank you...
There is a fix for making the new incal discs work on Insite 7.6. It is a file converter. I will see if I can get a hold of it and post it here.
colh (6th September, 2016)
need password for 7.6.1.195 pcid 11F9D337
also need it for 7.6.2.240 sp5 pcid 8C0CED31
thanks in advance.
Basic 000-D41-4C2-584-FD5-000
Lite 001-7FB-7F1-BD7-E83-000
Pro 002-8BE-4FF-D57-295-000
Pro Plus 008-0CD-257-6AD-328-000
Usage counts : 107
Fleet Calibration Counts FZZ-A7F-F9E-499-A03-5M9
OEM, ECM Password Removal ZZZ-249-76C-006-666-5M9
ECM Password Removal WZZ-769-B0E-3C0-768-5M9
Can someone please help?
7.6.2.240 sp5 pcid ECDA1477
thanks in advance,
There should be more characters for pcid
Corrected. the information
