Results 1 to 4 of 4
    Apr 2016
    Default Opel corsa-c error P1616
    Hello mates! I have a problem with a opel corsa c from 2004...i have changed ecu with another used... i have reset and reprogram all ok...but i have error p1616 and car start just for 2-3 second after cut off...i try to reset instrument but nothing. Can anyone help me? Thanks!
    racin-snake's Avatar
    Jun 2009
    RESET BCM and CLUSTER also check can wiring on inner wing green and white twisted pair for can
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  3. The Following 2 Users Say Thank You to racin-snake For This Useful Post:
    danielgatan (3rd August, 2016), super jumbe (2nd August, 2016)
    Apr 2016
    i have reset BCM..."instrument connect and disconnect fast" i cant reset...wiring all good
    Apr 2016
    SOLVED! Problem was from sw opcom...first i used version 2010....now i try it with 120309 and works. i reset and program and after all ok Thank you for all!
  6. The Following User Says Thank You to danielgatan For This Useful Post:
    Meat-Head (3rd August, 2016)
