Results 1 to 4 of 4
    Feb 2016
    Default JUMPER VISTEON DCU102 EGR
    Hello!
    I Have problem with EGR, somebody can help me with remove EGR and fault codes?
    I will be gratefull when you send tested and 100% working solution.
    SW:9665066380 HW: 9661256980
    File from FGtech v54 Boot .
    nizarben's Avatar
    Dec 2013
    mariusica_boy's Avatar
    Your file egr off.
    Pass in PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
    Hi.
    I have a similar ecu and problem with EGR. I need disconnect the plug too.
    Please help me! thx
