Page 101 of 172 FirstFirst ... 519196979899100101102103104105106111151 ... LastLast
Results 1,501 to 1,515 of 2580
  1. #1501
    Quote Originally Posted by remapecu View Post
    Today BSi continental on Peugeot 508 my2016. Mileage done but erase keys and after not possible to recover keys or programing so be be careful...
    Wysłane z mojego JSN-L21 przy użyciu Tapatalka
    How did u manage to fix? If you have
    Sent from my SM-N960F using Tapatalk
  2. #1502
    Quote Originally Posted by javyb View Post
    Didn't fix waiting to visit in dealer...
  3. #1503
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Smile
    All p508 works fine and always is possible to recover
  4. #1504
    Quote Originally Posted by cokolo View Post
    So you want to recover my 508? I have pincode but bsi doesn't accept pincode ( to verify I ordered in a delear pincode as well) so now I can't learning key's for some reason so last think I can do is visiting in a dealer?
  5. #1505
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    smok uhds always says update internal clock for every operation even after update done has anyone had this? (yes i have internet connection) its been happening over the last 5 days
  6. #1506
    Sep 2015
    I had problem also for program keyless on citroen. did you try to choose continental 2015 and go to advanced and write your pincode ? after that program it with fvdi.
  7. #1507
    No i didn't but will try before car go into dealer...
  8. #1508
    Apr 2016
    uk
    Anyone tried to program keys for Peugeot 508 2011 keyless system?
  9. #1509
    Not needed to visit dealer.
    in instal folder search for flsCNT2m.bin
    next reflash bsi.
    and after reflash write backup config (xls file)
    and done !!!
  10. #1510
    Quote Originally Posted by Rachon View Post
    Yes that work. After programing same pincode I was able to learn keys. Car started... Thanks Rachon your idea was great...
  11. #1511
    yes mate i changed usb cable and solved..
  12. #1512
    Jan 2009
    I have golf5 2007 with burned dash. Tried to adapt used dash, I found pin code,and with VCDS when going in channel 50 after 5min give me access to enter ori car pin code to adapt to engine ecu. When good pin entered vcds write "function not ok" instead to shows ori VIn....
    Then I readed edc16 pin ,vin,immo nr,and CS,open sec data from used dash and manually change data,then cheksum and save. Then I put this sec bit ,goes to immo3 entered pin,login...after this all data is changed except mac2,and can't reprogram ori key
    Any tips?
  13. #1513
    Quote Originally Posted by ziko View Post
    Any tips?
    I do not fully understand your explanation. but what I think is that you have to go to, "edc16 advance" and that the immo data has to be changed, so that the mac is learned.
  14. #1514
    Jan 2009
    But I changed instrument cluster not ecu,if I change immodata in edc16 then keys will not be able to relearn
    Edit: I just saw in help that you are right,in edc16 I write ori car data just to learn mac1,will try next car
    Edit: maybe must use new megamos
    But lets say I have both pins ori and used dash,why can't adapt with VCdS
    I usually put in 25 used dash pin,then adaptation channel 50 to merge used dash with ecu,and after all I reprogram iri keys. In this case not going so,in channel 50 after I put ori pin instead to show on top ori VINetc shows "function not ok"
  15. #1515
    soxten's Avatar
    Mar 2013
    Desolder Eeprom and flash from broken dash and move to used dash.
    Must be same number and version number.
    Fastes way
    Skickat från min iPhone med Tapatalk
