Page 108 of 171 FirstFirst ... 85898103104105106107108109110111112113118158 ... LastLast
Results 1,606 to 1,620 of 2560
  1. #1606
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Ok. Sorry i look. Carprog
  2. #1607
    Quote Originally Posted by peko View Post
    tiguan 2012 TFT not work
    no way to read skey ...
    prepar epp also no way to read skey ...
    not write but not crash
    What you have to do is put ignition on, and at the same time push read skey obd.
    sometimes you have to do this method a few times, but it will work
  3. #1608
    peko's Avatar
    Quote Originally Posted by gijsvm View Post
    yes i know it
    i made it lot of times, also remove battery during 10 min ... no way friend to read S-key
  4. #1609
    Oct 2018
    Tried Berlingo 2010 today, JC BSI.
    Block synchro don't work.
    Original KM jump back.
  5. #1610
    Apr 2016
    Is there MM dashboard? You need to do dashboard manually...
  6. #1611
    Mar 2011
    EU
    I had this problem few month ago.
    No way to read skey golf 6 audi etc...
    I make an update and now work fine.
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  7. #1612
    Oct 2018
    Quote Originally Posted by alkaskad View Post
    Yes.... MM dashbord...
    Need remove it ?
    Block synchro will never work ?
  8. #1613
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    did you read Marelli 9MD ?? I read .. but still not written!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  9. #1614
    Can hyundai ioniq be done with Smok ?
  10. #1615
    Quote Originally Posted by r6eck View Post
    Yes it can be done
  11. The Following User Says Thank You to gijsvm For This Useful Post:
    r6eck (9th May, 2019)
  12. #1616
    I see it now
  13. #1617
    Oct 2018
    Quote Originally Posted by centrohifi View Post
    I read 9DF, not 9MD
  14. #1618
    Oct 2018
    I read and write *
  15. #1619
    Feb 2011
    Hi All,
    Renault Trafic EDC16,and EDC17 work ok by OBDII with smok?
    Regards,
  16. #1620
    Mar 2011
    EU
    Quote Originally Posted by km666 View Post
    Hi All,
    Regards,
    You can't erase main odometer in ecu by obd, only some location. Must read the ecu by bdm
