Page 112 of 171 FirstFirst ... 1262102107108109110111112113114115116117122162 ... LastLast
Results 1,666 to 1,680 of 2560
  1. #1666
    toutougsmserver's Avatar
    Jan 2013
    inside map
    dacia 2014 dashboard+block abs there is a bug in last update
    tried 3 dacia same problem read flash stop at 20-25
    i used old software and all ok
    hope they solve that in next update
    VAG Bcm2,pcr2.1,edc17,med17,MED9.1.1 immo clone & data transfert
    PSA sid208 immo clone,synchro to bsi
    RB4,RB8 DEF FIX
    ODIS-S and E full install via remote
  2. #1667
    ghostrider72's Avatar
    Jul 2012
    UK
    Did someone programmed spare proxy key to Citroen C4 Grand Picasso with Smok? 2016 if that matters
  3. #1668
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by ghostrider72 View Post
    I do one.
    But to the keyless work I always use the diagbox.
    With Tapatalk
  4. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    ghostrider72 (17th July, 2019)
  5. #1669
    Jul 2012
    UK
    Quote Originally Posted by didi_du_93000 View Post
    I do one.
    With Tapatalk
    Is it easy to find that function in Diagbox? I’m using it very often
  6. #1670
    Milage doctor's Avatar
    Feb 2019
    hi guys just brought a uhds from smok but it come with only a obd cable. where can i get the other lead for the pc? also where can i download the software//.. many thanks
  7. #1671
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Milage doctor View Post
    Usb lead eBay software from their download section
  8. The Following User Says Thank You to teerak2uk For This Useful Post:
    Milage doctor (13th August, 2019)
  9. #1672
    RIMKACHIP's Avatar
    Feb 2012
    I noticed that I can not connect anymore bsi Siemens Kline since the last updates !! I have the message that tells me to connect pin7 to pin 11 for Uhds<5000 sn .while it worked very well before. could someone check please thanks. I don’t know if my device have problem of software problem or obd cable.
    Envoyé de mon iPhone en utilisant Tapatalk
  10. #1673
    Feb 2018
    I want to know how to use it. I am a beginner. I need your help.
    kia / carnival 2016
    Change cluster mb91f061 km
    ecu edc17c57
    I want to change dpf km .......
    I want to match the cluster
  11. #1674
    Feb 2018
    kia / carnival 2016
    ecu edc17c57
  12. #1675
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Module Renault RT0021 Talisman Megane4 Kadjar ...ecc .ecc 440Euro .....
    "Attention does not work on Kadjar 2017 " ... reading error !!
    sent eMail for info ... DO NOT RESPOND !!!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  13. #1676
    France Paris
    Quote Originally Posted by centrohifi View Post
    In your dream reply of smok support!!!
    With Tapatalk
  14. #1677
    baltazar3's Avatar
    Andromeda
    Hello to all !
    Today try to swap PCR2.1 on Octavia 1.6 TDI.
    PIN from dash is 1407 and SMOK say "PIN to short" ...is 01407 have to enter ?
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  15. #1678
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by baltazar3 View Post
    Hello to all !
    Yes sometimes need to put 0 as first digit
  16. The Following User Says Thank You to teerak2uk For This Useful Post:
    baltazar3 (25th July, 2019)
  17. #1679
    Oct 2015
    AGAIN C3 from 2013 bsi valeo can't read pin code from bsi, can't programm key also. pin extracted with adv function with one working key. asked in smok via my dieler several mounts ago. they said my laptop bad or usb cable no good. still no fixed this problem.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  18. #1680
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    repetitive response, assistance !!
    I have all Dell ... them, which laptop to use ??
    today I can't read dash Dacia Stepway .. worked other dacia OK !!!
    maybe too hot !!!
