KADE007 (26th September, 2019)
All key in here..........
https://www.digital-kaos.co.uk/forum.../177-Locksmith
ford edge & mondeo not work also
KADE007 (27th September, 2019)
hi! i need do iveco 2019 with smok i buy option but not fonctionne!! the dashboard 24c16 and the body 25320 please help
solomaxe (27th September, 2019)
pls i reed bcm and dashbord with upa i need 9700 km pls pls pls my freind
Just Done Talisman 2018
Turn the engine ON
1st ABS (5min max) read then write
Dash
1st I tried to read flash through Visteon. It turned off, refused.
Then I read through Continental high and it works.
When Writing, you have to do it twice .
Around 30min to read and 30min to write.
Cheers.
hello
please golf 7 JC works perfect with smok ?
any idea?
I need change language of V70 2016 from cluster to German, does smok also have flash files for clusters?
hi guys.
does the trafic 2018 still has same issues like clio4: gives incorrect information about trip average consumption, how many km's left to drive with current gastank, on the lcd screen in dash?
(this happens when you block abs in clio4).
thnx.
Guys what is your succes rate smok v/s new mb like W176 etc.
I have max 1 out of 10 W176 always unlock error.
I know a 2016/2017 is always dash out but the oldest W176 also can't unlock by OBD.
What is a good tool for newer Mb.
A en B can be done by eep but for w205 no option with smok.
Wbr Adam.
hello, someone has tested the smok 35080v programmer in the bmw 2016 35160wt eeprom.
