Page 118 of 171 FirstFirst ... 1868108113114115116117118119120121122123128168 ... LastLast
Results 1,756 to 1,770 of 2560
  1. #1756
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by foufoucne View Post
    you test it ??
    I tested 3 cars JC (2013/2014), 2 normal cars and one keyless, the keyless car gave problems while trying to flash the dash. The can bus is only 10 seconds alive so the car could not be flashed (init error). Software takes too much time to load the flash and start flashing, car dead but can be solved.
  2. #1757
    Hello, someboy tried to make w212 facelift with fbs4, does block synchro works on this model?
  3. #1758
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by drpeter View Post
    Can't you do this on desk, I see cable sets for making keys should be possible I think
  4. #1759
    Oct 2017
    Bought full Smok and had it delivered today , all I got was UDHS box and obd2 lead , I need to do VW Golf and Passat both with Johnson Controls speedo, do I need JTag or eeprom adapters to sort these dashes or are they totally obd2 now ??
  5. #1760
    Dessert
    Quote Originally Posted by Aislingob View Post
    You need jtag mate
  6. #1761
    Oct 2017
    With latest software is JC ZZGolf not 100% OBD2 ??
  7. #1762
    You need jtag and uhds. look at smok JC manual and you see how it works
  8. #1763
    In EEP
    I think newer go JC obd2 job. With jtag need reset data area in MCU. Pflash is no problem but Dflash is secured and non programe part. Now not exist way. Its good so slovak sell security access to mcu. If not still is alcatraz.
    Now is possible reset only mileage but flashing counter not
  9. #1764
    Apr 2019
    Hi Guys, i am newbie. i need to change odometer my alfa 159 2007 Diesel.
    what is best possible way to do it??. and can smok do it on dash and ecu???
    how idiot proof it is??
    thanks everyone.
    and you guys seem pros, where can i find a guide to learn this stuff like using programmer etc.
  10. #1765
    peko's Avatar
    Quote Originally Posted by chadvic53 View Post
    thanks everyone.
    what is your engine ecu ?
    you will also del all DTC presents in all ecu
  11. #1766
    Mar 2011
    EU
    Quote Originally Posted by Nicolas9 View Post
    hi guys.
    does the trafic 2018 still has same issues like clio4: gives incorrect information about trip average consumption, how many km's left to drive with current gastank, on the lcd screen in dash?
    (this happens when you block abs in clio4).
    thnx.
    Yes same problem with Trafic, trip, consumption doesn't work after mileage change...
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  12. #1767
    Nicolas9's Avatar
    Feb 2017
    Aruba
    i've done 1 keyless with succes. only last step by obd didnt work on first try (when you begin dash is black), but eventuelly it worked. i guess i was lucky.
    but how to fix if dash stops during flashing and dash go's black? i guess need to restore flash some way.
  13. #1768
    Reflash on bench
    Sent from my SM-N960F using Tapatalk
  14. #1769
    Apr 2019
    Hi Peko
    Alfa Romeo 159 2.4 JTDm 20V
    Body Computer Marelli (939)
  15. #1770
    Top Poster ekvas's Avatar
    Sep 2011
    eu
    FIAT
    IAW5AF P4 HW 603
    I PROBE CHANGE KM in ecm, NO
    probe in obd and probe in wiriling diagram smok
    identification OK
    go service mode OK
    probe change km, no change
    i read eprom, can help,
    now is 107094
    please i need 150000 km
    regards
