Page 11 of 172 FirstFirst ... 6789101112131415162161111 ... LastLast
Results 151 to 165 of 2579
  1. #151
    Apr 2013
    Maybe programmer start kline because you didnt connect CAN.
  2. #152
    Jan 2016
    Yugo if it would be like this then for me its useless option.
    If I get ELV from scrap I must buy dash with it to have CS... ??
    Quote Originally Posted by yugo45 View Post
    For PQ35 ELV you need to know CS and pin form car where was taken to be able to adopt it. I do not thing there is any tool at moment that will not read any info form PQ35 ELV.
    Same thing with Transmission on Audi A6.
    Read Info means only to connect to right module.
  3. #153
    yugo45's Avatar
    Quote Originally Posted by amigokola View Post
    Yes or ECU.
  4. #154
    Nov 2015
    Hi all, i had my smok PSA one month ago, I tryed a C3 Picasso 2009, It did the bsi, but not the block syncro (finally I did it with abrites clone and everything worked) then I tryed a citroen berlingo 2008, it did the bsi and said lock synchro selected, but when i disconnected battery to check it cames as original (abrites clone worked) today I did a 207 and same bsi done, but lock syncro not possible (abrites clone worked). Can you please tell me where i do wrong please? I do everything with dash connected.
  5. #155
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by hark87 View Post
    Abrites (fvdi?)
  6. #156
    Jan 2016
    Somebody used RB8 key learning with X-CAN ?? It does normal key learning procedure or add key with key maker to dump ??
  7. #157
    Nov 2015
    Quote Originally Posted by teerak2uk View Post
    Abrites (fvdi?)
    Yes the FVDI clone
  8. The Following User Says Thank You to hark87 For This Useful Post:
    teerak2uk (4th February, 2017)
  9. #158
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I did C5 2012 dash and bsi no problem.
    BTW berlingo and 207 dash is not listed
  10. The Following User Says Thank You to Faraday For This Useful Post:
  11. #159
    Nov 2015
    Yes 207 and berlingo are not listed, but with block syncro should be done, or not?
  12. #160
    Faraday's Avatar
    May 2012
    How it can suport something that is not listed?
    IMHO PSA-BSI from smok is nr.1 in BSI
  13. #161
    Quote Originally Posted by Faraday View Post
    If you read the smok website it clearly states that you can block sync on Citroen berlingo, Peugeot 407, 207, 308 so that the dash does not need to be corrected
    Sent from my SM-G935F using Tapatalk
  14. #162
    Nov 2015
    Quote Originally Posted by javyb View Post
    Indeed I did block syncro with berlingo and it says "block syncro selected" (so I hoped it could work) but when I disconnected battery all come back as original
    I am supposed to disconnect dash to have block synchro work properly? Maybe only disconnect the dashboard fuse?
  15. #163
    Aug 2015
    How is it possible to add key in Keyless pq35 System??
  16. #164
    yugo45's Avatar
    With Key learn function.
  17. #165
    Aug 2015
    In cluster ? In pq36 elv is no learn key function
