hello.y tried today in mazda cx3 year 2015
read correct but not write.enny solution please?
You have selected mx3, isn't there a mx5 option?
I did this car with obstar x100.
Wbr
Yes i do a few till now, It was just one problem till now but i fix it: golf 7 JC before to reflash don`t recognized the key anymore . after you installed back the dash you need to turn on the ignition to can reflash the dash.
hi guys.
where is dsg module located (to put dsg filter inside)
thnx.
Put filter in gateway module
Envoyé de mon LYA-L29 en utilisant Tapatalk
Nicolas9 (15th January, 2020)
some tools say -unsupported version- when try obd for CLA and W176..
mostly i do manual eeprom, is easy. but for a friend i need tool to do by obd.
does SMok do these by obd succesfull, or also say unsupported version?
thnx
Same story here, I can't remember the last one done by OBD always can't unlock.
Wbr Adam.
Default golf7 mqb
Hi guy .... by mistake i correct an odometer in golf 7 mqb i write 1230000... instead 123000.... the vehicule start normally but defaut on dash .... if i rewrite with good value it will be ok ?????? Thanks a lot
Hello, Can smok do full job on volvo v70 2015 via obd? or do you always have to do door module in other way to prevent km from jumping back?
Thanks.
Recently bough SMOk UHDS, have anyone done ECU mileage correction with smok. Think it only does dash?/?
friend experience on w453 dash and abs ?? I should activate the modules and I would not want to find a negative job
