Page 130 of 171 FirstFirst ... 3080120125126127128129130131132133134135140 ... LastLast
Results 1,936 to 1,950 of 2560
  1. #1936
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by sjc1 View Post
    so no issues with reading and writing both memories?
    There are always risks buy reduced with common sense and ask advice on models and how others do it
  2. The Following User Says Thank You to teerak2uk For This Useful Post:
    sjc1 (5th May, 2020)
  3. #1937
    Nicolas9's Avatar
    Feb 2017
    Aruba
    any guys experience with obd filter for mercedes to block ezs reading?
    i found how to set the filter, but dont know how to connect the filter to obd plug..
    thnx
  4. #1938
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Nicolas9 View Post
    thnx
    What brand blocker and put inside ezs
  5. #1939
    didi_du_93000's Avatar
    France Paris
    thnx
    Cut can bus wire from obd2.
    Connect bloker between car can bus and obd2 can bus.
    Job done.
    Of course need also 12v and gnd.
    With Tapatalk
  6. #1940
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Info ............ you have activated module " EU0035 Toyota/Lexus Airbag Modules on R5F617xx Read Flash by CAN (module conector) " ?
    since this form only reads! but can the file be saved? I read that to clear I must also cover the form " JG0013" !
    I don't see button write!
    I do the clear! but then to write?!
    I asked them, never an answer !!!
    ThK
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  7. #1941
    honingkoning's Avatar
    Dessert
    Is there someone who did Astra K successfull with smok?
    I always get message (2017 not supported)
    Wbr Adam.
  8. #1942
    Nicolas9's Avatar
    Feb 2017
    Aruba
    2017 is different than 2016.
    but by eeprom is fast and easy
    NO Selling Please !!
  9. #1943
    Team dz's Avatar
    Apr 2017
    ALGERIA
    renault symbol 2017 .... 2018....2019 and dacia abs bosch not support with databess
    note abs without esp ...... not suport work manulment with eeprom 95640
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  10. #1944
    Aug 2013
    Is there a new smok prog available or a repair? hae used this for 8 years and in last year became un reliable.
  11. #1945
    Apr 2014
    Has any one had success reading me7.6.2 on bench i cant get any comms via can k line etc
  12. #1946
    biya's Avatar
    Jun 2016
    the world
    I have a dash to modify for c3 2018 with mcu rl78. is what smok uhds + activation pt0016
    only can modify this dash. for the bsi I can put it in 0km
  13. #1947
    Dec 2017
    guys need to change vin on renault megane IV from 2019 Foto..jpg wil it works with this option ? anyone tryed before ?
  14. #1948
    Top Poster KADE007's Avatar
    Jun 2019
    FRANCE
    Hi, I have tested this option on new kangoo and works but not on all modules.
    I have finish the job with Renault ecu tool and launch.
    The thanks button does not burn, you can press it without any risk !
  15. #1949
    France Paris
    Quote Originally Posted by shotaaa View Post
    Not working on megane iv
    Must use beter tool.
    This function is big shit.
    I have it.
    Beter to take renolink or ddt2000
    With Tapatalk
  16. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    KADE007 (10th July, 2020)
  17. #1950
    Sep 2015
    Does anybody tested read D flash RH850 R7F7010183 with Smok jtag ?
    And what do they mean with :
    • when reading Data Flash, cells that are not programmed return random values)
    Flash
