Page 131 of 171 FirstFirst ... 3181121126127128129130131132133134135136141 ... LastLast
Results 1,951 to 1,965 of 2560
  1. #1951
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by Team dz View Post
    renault symbol 2017 .... 2018....2019 and dacia abs bosch not support with databess
    note abs without esp ...... not suport work manulment with eeprom 95640
    I tried the bosch abs option on a clio4, i never try the bosch smok option again, it erases the flash without warning while trying to read the eprom. If smoks database is wrong then it writes the wrong flash in de abs and yo are ~~~~ed. Even the dealer can not fix it. Only if you buy an new abspump (1800 euro).
  2. #1952
    Sep 2019
    Quote Originally Posted by drpeter View Post
    Yes, I had the same thing. the support team said that you can fix it by flashing it (flash file inside the smok folder), but it didn't, and I bought a new abs module.
  3. #1953
    please somebody with vw immo tool try to make immo off in eeprom dump on edc17 ecu
    worked for me before few months, soft now make nonsense dump
  4. #1954
    Apr 2014
    2018 Range rover Velar mileage and read and write eprom working ok?
  5. #1955
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by sjc1 View Post
    Yes. .
  6. The Following User Says Thank You to teerak2uk For This Useful Post:
    sjc1 (13th July, 2020)
  7. #1956
    didi_du_93000's Avatar
    France Paris
    C4 picasso tft with Delphi bsi.
    Bsi Delphi is ok.
    Dash tft not working (error security)
    With Tapatalk
  8. #1957
    Quote Originally Posted by shotaaa View Post
    guys need to change vin on renault megane IV from 2019 Attachment 728972 wil it works with this option ? anyone tryed before ?
    Works well, but before you have to erase ori vin in ecu to FFFFFFFFFFFFFFFFF, next do change vin, and all ok
  9. #1958
    France Paris
    Quote Originally Posted by gijsvm View Post
    Not working!!!!
    If need to remove all ecu from car its shit.
    Megane 4 have more than 15 ecus.!!!
    With Tapatalk
  10. #1959
    Sep 2015
    UK
    Renault Talisman dashboard high read / write flash ok! But no chance to change VIN or read eeprom and change hidden mileage.
  11. #1960
    Sep 2015
    UK
    two attempts to clone Simos PCR2.1 failed.
  12. #1961
    Quote Originally Posted by didi_du_93000 View Post
    Not working!!!!
    With Tapatalk
    Only motor ecu have to fill to vin to FFFFFFFFFFFF, next do write vin and all other vin modules will be write
  13. #1962
    Quote Originally Posted by thorino View Post
    Your obviously doing it wrong then. U cant clone Simos Pcr2.1 u need to adapt the immo to car I have done a good few and all went perfect
    Sent from my SM-N960F using Tapatalk
  14. #1963
    --two attempts to clone Simos PCR2.1 failed.--
    with uhds not clone pcr2.1. only programming immo data and write flash,work good
  15. #1964
    Apr 2019
    I have UHDS and PTP1, I was wondering if it will correct dash in a 2019 Peugeot 3008 with Delphi 2016 bsi.
    I can read and get correct milage in BSI module on laptop, however when I select dash module and read 3008/5008 dash it reads incorrect milage.
    Would I need to purchase another licence?
    I'm really struggling to get any assistance with the product.
    Thanks in advance.
  16. #1965
    France Paris
    Quote Originally Posted by dacs View Post
    Thanks in advance.
    3008/5008 dash on smok is old.
    3008 model I
    5008 model I
    Must open dash and read eeprom inside.
    With Tapatalk
  17. The Following 2 Users Say Thank You to didi_du_93000 For This Useful Post:
    dacs (19th July, 2020), KADE007 (19th July, 2020)
