have you tried another car ? does it work ?
I had the same problem few weeks ago (init error/ read error), doesn't work with with some bsi, need re install sw and now work.
Having trouble making 2016-2017 continental bsi for obd 308?
BSI Continental 06/2015...
Checking BSI...
License Accepted
Init Ok
SW ref : 9692010480
SW Edition : 131.60
Flash Counter : 2
System : B3
Application : 20
Cal ver : 01
HW Ref. : 9674745380
HW Add. : 9806687880
ECU Continental Detected
VIN: VF3LCBHZ3HSxxxxxx
PSA Model Year: 2017
Peugeot 308 II
Actual km:194456
History no empty
ACK 31: 0000000000000000
Service Mode Entered
Check Ok
Reading EE...
License Accepted
Init Error
Read EE Error
Sesion Stop 15:59:35
Master Alientech, Magicmotorsport, Autotuner, file service,
Click on Thanks and Reputation if I helped you! Thank you
Anyone having trouble with C-Elysee 2013 BSI Valeo, after connect now with 0 mileage, cant change.
Tried only dash tool itself when read log displays desired mileage 170000 but dash show 0 on display and BSI also 0 on UHDS Tool log.
Insignia airbag crash data reset via obd working?
hello guys, i had peugeot 3008 from 2019 with delphi 2016... all key lost situation, after reading pin with succes, i tryed to add key, it says add key succes but the car dont start, remote of the key is working, keyless entre is working, but car dont start ..... any suggestion what the problem could be ?
Have you tried reading fault codes to see what comes up? More information will help with a solution.
Hi guys, I have a question if the SMOK UHDS with the NS0001 license Nissan OBD changes the mileage in the Nissan 2009 -... HCS12X all models or one in ten ?
Hello all guys,i want to know if someone use smok jtag to read renesas rl78mcu r5f10wmea from kymco dashboard,i want to know if it work? and if some one can expalain how work? thanks to all in advance!!!
How to make a MB W213 since 2016?
Jeep Patriot 2006
Ok, in 2 seconds
Guys did somebody succed to virginize psa delphi bsi 2016- i have tryes couple of times but didnt succeed !?
any feedback about smart 453 dashboard tft color with smok?
i made one last year and never power up after programming mileage with smok
ProTuner since 1999
