Page 135 of 171 FirstFirst ... 3585125130131132133134135136137138139140145 ... LastLast
Results 2,011 to 2,025 of 2560
  1. #2011
    Aug 2016
    Hello, i use SMOK for more than 1y no problems, but today i do MB CLA w117 2016y . I try with and without can filter (also smok) but whatever i do mileage is staying same. It says security access 1 ok 2ok 3 ok but after that eeprom unlock error. Any help on this?
  2. #2012
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by digitalol View Post
    Not possible by diag, need to remove dash and go direct by eep.
    Easy job but you need to fit a filter
  3. The Following User Says Thank You to honingkoning For This Useful Post:
    teerak2uk (17th November, 2020)
  4. #2013
    Feb 2020
    I am about to order smok but was wondering this evening . Once I have read and saved a flash file can I alter the mileage in that file using smok like I can with for example the Russina S-tool . Or would I need to do it outside of smok
  5. #2014
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by westlo View Post
    Download smok and run it then you'll see features in sw
  6. #2015
    Jan 2019
    Quote Originally Posted by brend View Post
    For this need know tricks!
    And for solve fully this probleem door need set to.
    Anything you can assist me with?
    I am willing to pay for that kind of service..
  7. #2016
    Jan 2019
    Quote Originally Posted by honingkoning View Post
    Then you are ~~~~ed.
    Files are also kept in a backup folder
    Where is the backup stored?
    Problem is... it did not prompt to save any kind of file on the harddrive as it normally does with other vehicles.
  8. #2017
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by gttuning View Post
    Hi guys..
    CAS4 1N35H r they ok to read with smok ??
    Sent from my SM-G955F using Tapatalk
    I use XEP100 - Very good.
    Don't buy Simon Touch clone tho!!
    Solidarity with Ukraine
  9. #2018
    fred77's Avatar
    Jun 2019
    Can i ask coverage advice guys please, just fed up of buying kit which doesn't work :'(
    Smok on VW Caddy 2017 ?
    Any "unsupported dash messages" - ie does smok work good on ID48 AES.
  10. #2019
    Dessert
    Dot after doing cas 3 by diag.
    All cas 3 I was able to do by diag (with smok) leaves the known red dot.
    What is your experience with this?
    I tested today on a x5 and a mini, the funny thing is that the cn digiprog does the job without red dot (same cars tested with smok en digiprog)
    I there a way to avoid this dot with smok tool.
    Wbr Adam.
  11. #2020
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Wbr Adam.
    Any errors with diag tool
  12. #2021
    Dessert
    Quote Originally Posted by teerak2uk View Post
    This is a known problem and easy to fix by driving like 30km.
    But I want to understand why this happens with smok and digi China does a good job.
    Best is TU use programmer of course but I am just curious why it always happens with smok.
    Smok is very fast on cas 3 Btw
  13. The Following User Says Thank You to honingkoning For This Useful Post:
    comizelu (24th November, 2020)
  14. #2022
    Apr 2016
    uk
    Sorry,I'm not an expert on mileage..
    Can you do case(+) by obd?
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  15. #2023
    Dessert
    Yes it can but not all cas3 plus
  16. #2024
    Apr 2016
    uk
    What about the dash?
    Will it take the mileage from CAS?or do it on bench?
  17. The Following User Says Thank You to comizelu For This Useful Post:
    honingkoning (25th November, 2020)
  18. #2025
    Dessert
    Dash always on desk
  19. The Following User Says Thank You to honingkoning For This Useful Post:
    comizelu (25th November, 2020)
