I have XC60 2012 and i try to use VO0017, But i get "Unknown Version" on both Read KM and Set to 0, Does this mean this car does not have km in DDM/PDM?
Thanks.
Thanks.
yes , smok.pl said there was an issue with the software that they have now addressed , i just need to test it
SMOK UDS some test ABS BOSCH Change mileage via obd
DACIA 2013-2015 Bosch ABS eprom 95128 OK
DACIA 2019 Bosch ABS OK
DACIA 2016-2018 Bosch ABS eprom 95640 not work..
Hello, Anyone have experience with Mercedes and SMOK? How reliable and what are the odds that it works? They have a warning on their packages that says "Not all software versions are supported".
fiesta 2018, newest model.
Dash Possible with smok?
Repinator (17th April, 2021)
SMOK UHDS version 3.7.2.2
-Change mileage on jc bsi Peugeot 308 2009....2012
I have test fast write with lock dash-bsi mileage ---> result is no mileage on dashboard... Just "-------"
After that I have write back original all work great.
-km peugeot partner 2015...2018, BSI (Jonson Control. (SPC560)) done OBD ok.. dashboard? Obd does not work..
-km peugeot partner 2011...2014. bsi (Jonson Control. Crypto) dashboard done OBD ok
I have golf6 with water damaged cluster, from new (used) I found CS, pin code... also on bench I found immo data from edc17ecu from car. In immo4 I put CS pin from used dash,in new immo I put data from car ecu and change immo goes ok,also here i program new key. Then by smok manual for mac1 I need to go in edc17 and put old and new data (which now is same) and press change immo, goes ok but on end LOCK TIME,and error write
Car start and stop,in immo25 no dtc,on dash no immobiliser active message...
Any tips?
P.S. in edc17 uds I cant write change immo, not on bench not on car, its possible only in edc17 TP
After 100min smok pass last job, but when i see dash sec block mac2 is only changed,mac1 remain same from dash, also mac 2 changes but not same as mac2 in ecu
