Willinickersen (24th October, 2021)
brend (25th October, 2021), Willinickersen (24th October, 2021)
HI FRIENDS
anybody have experience with MM 9GF ecu engine with smok ? to R/W flash
Hi All
I have a clio 4 with dead dash. Customer has purchased a replacement dash which has higher mileage than original. Would it be possible to disconnect ABS plug, change dash mileage to original value with smok, then reconnect ABS pump?
if this post was usefull
please press
the thanks button
hi friends
who test ECU Magneti Marelli Fiat 8Gxx, 9xx...
i need R/W flash from 9GF ECU ?
thank you
i hav 2006 model volvo s40 diesel with ECU SID 803A inside, SMOK software says it can copy p and flash . info on wire up is very vague, can anybody help me on this one
Hello mates,
I need to correct mileage Nissan NV200 year 2014 with monochrome (orange) display.
Is it safe with UHDS by OBD ?
I read that many people bricked dash due flash corruption.
Any advice ?
Thank you
It is safe if you pick correct version.
Smok will ask if reverse camera or non reverse camera dash
Sent from my SM-N960F using Tapatalk
Finally I read the micro backup on the bench with programmer and then did the job by OBD with smok.
It goes without any problem.
Anybody tried the immo software to program a key for Renault trafic 3?
Sent from my SM-F926B using Tapatalk
