Page 172 of 172 FirstFirst ... 72122162167168169170171172
Results 2,566 to 2,579 of 2579
  1. #2566
    Quote Originally Posted by atomiczen View Post
    try other tool or try to read eeprom and wait for someone edit for you
    I found hex values in both dumps, but not possible write abs eep or dash eep on clio5 with smok...
    I don't have Clio5 mileage activation on other tools...
  2. #2567
    Oct 2016
    Experience with smok on mqb dash
    SMOK problem with mcu connections specially on 35xx mcu and virtual dash
    on all same massage
    mcu not answer check connections
    support silent as always
  3. #2568
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by kina View Post
    on all same massage
    I've done a few never any issue
  4. #2569
    peko's Avatar
    hi friends
    who test key learning on new VAG ? working fine and safe and covered all version from 2020 ?
  5. #2570
    May 2024
    Default SMOK UHDS documentation - Opel Corsa D Tacho
    Hi guys, I have a SMOK UHDS with almost full license list activated.
    Being new to this product, I am wondering how their documentation works (in English).
    For example, I have an Opel Corsa D from 2014 (EDC17) and I need to do a tacho adjustment. How do I know if this is possible and which option to use?
    Thanks a lot in advance.
  6. #2571
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by MilosCuculovic View Post
    1.MultiEcuX
    2.Opel
    3.Ecu Dump Tool
    4. Bosch ............. all in here .
  7. #2572
    Sep 2023
    londra
    VW Passat hayalet gösterge paneli yapabilir mi?
  8. #2573
    May 2024
    Thanks @brend. So I need to read the ECU, do some changes and write the file back? My initial question was about how do I know this? Is there a documentation somewhere I can access and have a description on how to proceed with a given car?
  9. #2574
    May 2024
    Quote Originally Posted by brend View Post
    1.MultiEcuX
    2.Opel
    3.Ecu Dump Tool
  10. #2575
    brend's Avatar
    Oct 2015
    Same where
    What kind of documentation do you want for dump tool ?
    Or don't you know what dump / dump tool is?
  11. #2576
    Sep 2018
    hi,
    bsi q03-00 9665547480 citroen c4 2012
    read info ok, but when i try read eeprom i have BSI prog Mode Error..
    Any idea how to solve it?
    regarsds
  12. #2577
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by micost View Post
    hi,
    regarsds
    Are you making right selection also some don't read until you write km and it flashes bsi and saves backup in documents/uhds/temp
  13. #2578
    Sep 2018
    yes selection is ok, i try on bench with ioterminal and same situation, make info no problem but when i try read eep it cannot..
    i was try to write and then uhds gives this error
    READ EEprom failed
    BSI PROG MODE ERROR
  14. #2579
    amrif's Avatar
    EU
    Quote Originally Posted by ATRON View Post
    I need Dashboard repair MainFlash or full flash Hyundai I40 Fujitsu MB91F062 .I try by OBD2 with Smok tool ,all dashboard work fine but mileages goes only 1km up then 1km back.Mileage are Stopped.I have not good dumps for this dash ref. 94033-3Z300.Diesel ,manual gear ,made 11/2015.I hope someone send me dumps for help me.
    do you have this flash? The same problem.
    If I helped you please remember to give thanks and rep. A little thanks goes a long way
